Problem with Dataone
janitha, just try an install of an older windows version on some other partition. It just might work - for me it did
janitha said:
It gives "Local Area Connection Status" with provisions to disable, repair etc. Repair doesn't work, as I mentioned earlier. Disable makes the icon disappear, and with it Dataone icon and connection are also gone. Then I have to enable the network from the Device Manager.
there is a properties button. clicking on that will bring up the option plus another option which says - Notify me when this connection has limited or no connectivity.
disable both if you want or only the first checkbox.
Btw which edition of XP you're using? home or pro? cause these are available in the pro version. dont have home version so cant tell.
Reactions: 1 person
Thanks a lot. It worked. Repped.
XP Home OEM SP3 with uptodate patches. Have a XP Pro OEM Pack also which I have not installed yet.
