Graphic Cards problems with x1800xt???
:) :) Spending 25k and buying directx 9 hardware would be idiotic...whatever anyone says if you are going to spend so much get an 8800gts...Provide service and quality is good the BIG 8800gts seems a good deal...
:cool2: Do not go for anything else other than the 8 series.
vandal said:
6.1....thats old... I suggest you try 6.7 they're stable... I have problems with the x1900 with 6.9, dark crusade has missing text in places...
oops opps.... he s using 6.10..... used all drivers from 5.8:bleh:
guys strange problem with my x1800xt
3d05 runs without any problem.
yesterday i installed 3d 06 and screen was giving some problem at edge of screen. later when it comes to ship flying mode all screen was blue, green and blinking.. i cancelled the test.
what can be the problem ?
using 6.10 which comes default with card.
made proc and ram to run at default speed but no help.
temp of card is also not too high.. while running test max was 78
proc temp max - 49
nope.
i have just tried HL2.
let me try reinstalling OS and installing 6.11 drivers.
3d mark05 goes smooth but i dont know what what happens with 06.
havent faced any problem with other game.
let me try Fear and try max settings and check.
PSU is not a problem.
solved the problem by removing Fans. may be my PSU is crappy.
i had connected 3 x 120MM + 1 x 80 MM Fan. i removed 1x80+1x120+ LED panel of my Geforce case+Temp Monitor thing = stable 3d mark06 and HL with max resolution.
despite unplugging all Fans my temp is still - 34-34c:)
but this time i used 6.11 drivers and i installed .Net 2.0 after SP2 installation(full) and then applied plain drivers. got 9347 3d05 score without any OC.:hap2:
will try OC and check scores.... wish i could achieve 10k mark;)
