sabkabadlalegaterafaisal
Forerunner
Of course but it's still a downgrade, which is what i wanted to point out.You are not getting the point. Slower does not meant slow. It is still blazing fast, twice as fast as the SSD on Dell Xps 15.
I asked my uncle and is kid have a gmail Id :/ what should I do now ??? mostly they will get a outlook one as well as they use teams!Any student email ID works. .edu or .ac.in
They don't ask for proof when your email is auto-validated. Your apple account should be your normal email id, and your unidays account would be your student email ID.
Btw UNIDAYS also gives offers on several other brands. I bought a S23U in June/July and missed out on their discount because I did not know.
You mean `@gmail.com` or do they use Google Workspace?I asked my uncle and is kid have a gmail Id :/ what should I do now ??? mostly they will get a outlook one as well as they use teams!
Try M1 16" pro. It is the same for all intents and purposes. They are selling for 75K off.Hello,
Need help purchasing a Base model 16" Macbook pro - 16GB/512GB - M2 Pro chip on behalf of a friend.
Could someone help out with where can i get one at the best possible pricing ?
Thanks !
I recommend this as well. If you want it even cheaper, get the base m1 Pro 14 inch from the marketplace.Try M1 16" pro. It is the same for all intents and purposes. They are selling for 75K off.
Buy the latest Apple iPad / Tablet online starting at best Price in India at Aptronix | Apple Premium Partner
Buy the latest MacBook M3, M3 Pro, and M3 Max chips. Get up to ₹75,000 off on selected MacBooks, no-cost EMI and student discounts are available. Get free delivery across India. Shop now and unlock the exclusive offers on MacBooks only at Aptronix. Need repairs? Authorised service providers are...www.aptronixindia.com
Their website is taking ages to loadTry M1 16" pro. It is the same for all intents and purposes. They are selling for 75K off.
If you're okay with 14inch, the Apple student disount price will be the same after selling airpods. Its 1.84L less 15k for the airpods 3.Try M1 16" pro. It is the same for all intents and purposes. They are selling for 75K off.
Used someone's College ID card front and back scan. It was simple enough. No headache. Took 1 day to process at unidays.I asked my uncle and is kid have a gmail Id :/ what should I do now ??? mostly they will get a outlook one as well as they use teams!
I took 3 months of going to reseller stores to weigh the 14 inch and 16 inch, and make a decision. Went for the 16 inch in the end because the weight difference certainly doesn't outweigh better thermals, larger battery, better speakers, bigger screen, bigger trackpad and more wattage allowances.Just my 2 cents..
16 is much bigger and heavier than the 14.. certainly makes a difference while handling.
Please check if portability is your criteria.
Interesting thing is that many wont even reach the wattage and thermal limits in their usage. Its pointed to OP, let him decide!I took 3 months of going to reseller stores to weigh the 14 inch and 16 inch, and make a decision. Went for the 16 inch in the end because the weight difference certainly doesn't outweigh better thermals, larger battery, better speakers, bigger screen, bigger trackpad and more wattage allowances.
