.rar file extraction problem..HELP!
jumbo5
Contributor
i had downloaded a 700mb video file divided in 8 parts through rapidshare.
all WINRAR files....
after downloadin i'm havin problem for extracting the files.
i dunno from which thread i copied those linx, so i cannot track the user who uploaded these links.
Please help -
the problem i face is represented as follows -
1.these r the files which i have downloded
2.when i click on 1 part,it should join all files by default,but instead it shows more files -
3.then i click on 1 of the .rar folders which is inside the mail rar folder and i get about 20/30 more rar files like this -
4.then whien i click on 1 of them i get this -
5.then when i try to extract the file above..i get this!!!!
This goes on..files...more files..for extraction....more .rar files....wat is all this!!!..i'm confused...never seen such a thing!!!!
Please HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
me too had downloaded a file similar to this once with multiple nested rar's...ur only option is to keep extracting stuff from within the rars to one single folder at the end ull get ur video file and u can delete all ur rar's..not sure if im clear enough..
just right click on any one rar file and select extract (to folder) here.
if u get more rar files then do same as above till u get the avi file.
it seems as if the avi file was compressed twice or thrice here.
keep extracting til u really believ ki u have been fooled by someone ..
and from next time on, use only proper sources...
best of luck buddy ..
right click on part1.rar and click on extract here. it will b extracted and you will get the movie file in 1 part only.. these files are interlinked so the normal procedure is to right click the very 1st file and then choose on extract here. it will work for sure. try
just right click on any of the files and choose extract to ...and then choose any folder..winrar will join all those files and make tha avi
wat is HJsplit?some 1 gave gave me dat option.
btw thanx all...repped ya all..except spacescreamerr,buddy i'll definately rep u if i'm fooled,but as of now i know i'm not and secondly when i was surfing the thread there were praises for that video after all those linx were pasted by the uploader.Its just that i cannot track that thread anymore.
lol it is easy and drap and drop of use from winrar in some hard disk folder find it yourself
Yes its not that easy. You have to go on creating folders after folders and properly maintain the sequence of the files. It is a tedious job. Some fools go on creating multiple rars just for the sake of it. They have little sense....But you can consider upto 6-7 up/higher steps. More than that, well you can be fooled.
As for HJ split, it is a small software utility that helps to join or split a file. The file numbers are in the sequence of .001,.002 etc. You have to first choose the first file of the compilation i.e .001. After that the files like .002,.003 are recognised or joined by a automatic process, if they are in the same folder.
Good luck.
extract all the files from the first 8 (vida[1].guerra.part1 to .part8) rar files you have downloaded into a single folder one by one. Then open the vge-xvid-trust.rar from the folder and then extract the .avi file.
thanx ratna & espeez...repped ya both.
i'll try both methods.
@ ratna
they r not,or it would have been very eazee...the uploader is a fool i guess.
