Rechargable battery for RedGear Pro Wireless Gamepad
I Have a RedGear Pro Wireless Gamepad. Link Here and Finally the battery had died, Kept it for charging for 6 hours but didn't work.
So i need a good battery replacement for the controller.
Currently it's using 400mah, 3.7 Li-ion battery.
I'm ready to stick the battery to the back side of controller If i have to coz i need more capacity for longer playtime. Budget is 500rs.
These are two batteries i have my eyes on.
1500mah
and
1250 mah
and
3600 mah .
Please Help.
Since it has a flat battery, I think these should help
This should be an exact fit
This similar in size might be half an mm thicker
This is the highest capacity in flat form factor, It would fit but might take some convincing. I wouldn't recommend anything higher.
Look on the site
For 500 you can buy 2-3 batteries and try to fit the largest capacity.
Also, don't look for ultra-high capacity (>=4000 mah) those would be just 18650 in parallel and wouldn't fit in the controller. 2000-2500 mah would be the most practical and you wouldn't have to do a hack job.
Do let know when u replace it...as i am also having same issue with same gamepad but it does work sometimes.
i tried the 2000mah battery, but it was way bigger, had to stick this to the back side of the controller, otherwise it works fine . still can't figure out the charging time , had it charging straight for 4 hours but didn't see the charge full light.
What are the dimensions of the original battery if you can check.
