My brother has a Nokia 6020, which is quite old (about 4 yrs). Now this has developed some battery issues - the battery does not seem to hold charge for more than 6 to 8 hrs. So he wants to replace the battery with a new one. The battery is BL-5B type.
Now is it possible to replace this battery with a different spec battery.. something that has a higher mAH rating? I've seen a couple of such batteries from ebay.com, and they claim to be 1100mAH, while the original ones are 860mAH. However, these are non-branded Chinese makes which makes me feel queasy about them.
1. Can I replace the battery with a different Nokia make.. (BL-4B or BL-4C or something of that kind) - something which has the same 3.7V rating but better than 860mAH, provided the dimensions are similar?
2. What would be the performance gain in such a case..? How much of an increase in talktime are we expecting here?
3. Are there any reliable non-Nokia manufacturers of batteries for Nokia mobiles..?
