I'm not sure what the exact connector for the TripleFi is, and for some reason wasn't able to find it via some quick googling. But if they are the same as the KZ ZS5, then the below should fit, since they are the 0.75mm connectors present on the KZ:
Without mic/remote
With mic/remote
I personally have the SA Raven IEM from this store which comes with the 1 button mic/remote cable above, have had zero issues with it over my last year of ownership - very sturdy and no microphonics (or whatever it is called when the cable brushes against clothes and you can hear it). It seems they will ship once the lockdown in Maharashtra is over, so from May 1, but apart from that I can vouch for ProAudioHome, as I am sure many others can on this forum.
