I have a house which is about 1500 sq feet, 3 bed rooms, and a living room, basically i need a router which can give me a strong signal in all the rooms.
1.ISP :Local Cable Provider using the cable connection via a cable modem
2.Plan : 15 Mbps
3.Connection Type: Cable internet!
4. Budget is 8 - 10K
All the bedrooms are wired with Cat 5 ethernet, so my idea is to setup a media center using the router and stream media wirelessly/ wired to my smart television/ laptop/ gaming console. I am a little ignorant when it comes to this. I was looking at routers that allow you to plug in a USB drive to stream content.
If there are options like a media center also please let me know.
I was considering the following
Asus RT-AC66U / Asus RT-AC56U / RT 68U
Linksys E4200/ E3200
Netgear R6300 / Netgear’s R7000 / Netgear R6250.
All help is appreciated
2.Plan : 15 Mbps
