Hi Guys,
I am writing my First Review for TE and therefore would appreciate your views and opinions
The Review is of LOGITECH WIRELESS SPEAKER ADAPTER
Box Contents: 1. Logitech Bluetooth Adapter
2. Charger
3. RCA to 3.5mm Cable
Set-Up: Setting up the Logitech Wireless Speaker Adapter is a breeze. Just connect the adapter to the Wall Outlet, Insert a 3.5 MM jack or RCA Jack to the adapter depending upon the Speaker System. After that press the connect button on top of the adapter, the Red Light starts Blinking. Now just search the adapter through your device’s Bluetooth settings and connect, the light on the adapter will turn to a steady Green.
The whole set-up hardly takes a couple of minutes
Thoughts: The Logitech Wireless Speaker Adapter is a terrific device for everyone who wishes their speaker should possess wireless capability to play their songs through multiple devices over Bluetooth. It seamlessly connects to a wide range of devices and the range is excellent as well. But what blew me was the quality of sound. The audio quality is not deteriorated and the device does justice to the speaker output.
The only thing worth mentioning is that the Adapter doesn’t have inbuilt Battery and has to be connected to a wall outlet at all times.
Build quality of the Adapter is also quite good with the top and bottom being matt-finished whereas the sides are glossy. All in all it shall go well with almost all speakers setup and will feel as if they were part of the initial set-up.
Alternatives: The alternative to Logitech’s Bluetooth Adapter is Belkin Bluetooth Music Receiver. Although it is a bit cheaper than Logitech yet it has some flaws like you need to modify the device to extend the range. Also some report that the device doesn’t have nice audio quality and is a bit flimsy. Both Devices lack built in Battery.
PACKAGING
ADAPTER
BOX Contents
OVERALL LOOKS
--THANKS
2. Charger
PACKAGING
ADAPTER
BOX Contents
OVERALL LOOKS
--THANKS
