blr_p
Quasar
That's just an unbalanced spin. There should not be any shaking with an empty drum at 800 or 1000 rpm. At least not on the LG's but I've seen reviews on amazon saying it happens with Samsung. Well maybe then the machine isn't properly levelled. Or in need of a calibration. If it still shakes then something is loose and needs tightening.Tbh, the shaking use to happen when the spin cycle speed is 1000 rpm or 800 rpm. It also use to happen in another case, where if we wash few clothes by hand and put them in the drum without shaking off water or wringing the clothes to remove water before putting in drum. I tried 600rpm and it wasn't that shaky. Since then I started using only 600 rpm and never bothered much about it. That's why didn't mention it before.
A slower spin puts less stress on bearings. If you're OK with the longer drying time stick with it.We recently shifted to a different flat. My cousin who didn't know I choose the rpm specifically, just selected the default spinning rpm and then I noticed it didn't shake that much as before. That transportation probably did something to minimise shaking to a noticeable extent probably. Anyway I'll stick to 600 rpm only.
You said you used various descalers. Vanish isn't a descaler. But the surf one is. Did the noise begin after using the surf descaler? I've actually posted not to use it as earlier reviews complained it removed the shine from the drum. They might have altered the formula since. I figured they were the equivalent of toilet bowl cleaner from a manufacturer in France. Should descale fine but maybe more harshI never used citric acid to clean though. Initially for few years, surf itself as suggested by technician for drum clean. Then vanish as per ur suggestion. Then recently I tried the surf excel descaler itself.
Likely not levelled properly. Which then leads to loosening of counterweight and weakening of shocks due to excessive shaking and finally leads to premature bearings failure as indictated by aircraft turbine like noise. The machine isn't designed to work under such conditions.Interestingly my neighbor's washing machine shakes like there's an earthquake and sounds like an aeroplane takes off. Somehow they don't really bother about it at all. Probably waiting for it to give up and buy a new one ig.
Some brands will still proceed with such a spin instead of throwing an error and this leads to shortening the life span of the machine with the owner being none the wiser.
How old is your neighbours machine and what brand is it?
After that try an 800 rpm spin with nothing. There should be no vibration. If there is then see above.I am going to try the calibration methods today that were shown in the video you have posted.
And can you confirm your results here after
