FS: Others Senseimods custom 12 Pin to Dual 8 Pin PCIe Sleeved Extension power Cable 300 MM white
buBleZ
Level F
Feedback: +31 / =0 / -0
Bangalore
5 out of 5
  1. Cash
  2. Bank Transfer
Excluded - at actuals
NA
No
Not needed anymore
Senseimods individually sleived 12 pin PCIe power cable extension, white: Bought in August 2022 for 1750/-
Selling at 1300/-
Can I use this with a 3060 Ti FE?
It only uses half the pins on the 12 side and a single 8 pin from the PSU.
Yes you can. Since 3060Ti FE is low power it only uses half of the pins on the 12 pin side. Please note you cannot directly plug in this to the PSU. You need to use your PSU's default 8 pin cable and plug this to the PSU cable
Thank you and yes, I'm aware. Had a fun time separating Nvidia's in-box cable from my PSU 8-pin cable earlier today. No idea what happened but I need a new cable and a new PSU.
Only the cable that's supplied in the box with the 3060 Ti. I can't see any other reason for this spectacular failure. The same PSU powered a 1080 Ti at one point just fine.
