Hmmmmm.
Still I am thinking that its GROUND Problem. As the purpose of GROUND is to throw away the excess and body currents.
But, if it is not a GROUND problem, do these tests -
1. take power from a totally difference source, like from different room, not another point in the same room. Use a REAL 3pin extension cord.... borrow it from friends / relatives. Then start your PC, Test for ZAP.
2. If still, ON your PC, then take a TESTER and touch the body of the PC. If it glows very high then it must be 220volt, else 12 to 24 Volt.
A. if it is 220volt, remove the SMPS/PSU from the cabinet but keep all the connection intact. So, there will be no metal-metal contact between PSU and cabinet. Turn ON the PC. Now test with TESTER if - i. only PSU zapps ii. only Cabinet zapps. individually....
If only PSU zapps and cabinet NOT, then the problem is with you PSU. go for RMA.
else...... :huh: can't suggest anymore from here.....:no:
B. if it is of low-volt like 12-24volt check the cables of the PSU, may have some leak.
@max_ds and
@Stick
Friend, its not true. Motherboard should be used with metal screws. As if a PSU malfunctions and sends higher volt, good motherboard tries to drain the excess current to GROUND via the cainet itself.
SOURCE: Peter Norton's Hardware Guide book.
also written in your given link -
max_ds said:
One of the most common mistakes while installing a motherboard is using these washers on all holes. This cannot be done. The metalized holes were metalized to make the proper grounding with the system case.
