User Guides Simple way to unlock Sapphire HD6950 Dual Fan Editions to HD6970
Card Used/Needed -
SAPPHIRE HD 6950 1GB GDDR5
SAPPHIRE HD 6950 2GB GDDR5
SAPPHIRE HD 6950 2GB GDDR5 Dirt3 Edition
Stock Settings (I am using a 1GB version) -
A Little Story Behind -
I had overclocked my card to 900/1275 and was going to overvolt to get further. Before that i decided to read some user experiences at newegg. Saw this -
Bios Switch unlocks 6970 shaders.
So thats how the fun began. :D
How to Unlock -
1. You need to have a Sapphire HD6950 with a dual fan cooler. 1GB or 2GB both have good chance of unlocking.
2. Make sure the card is running at stock 800/1250.
3. Turn off the system, open the cabinet side panel and locate the BIOS Switch on the card. Its near crossfire bridge connector.
4. Flip the switch towards right.
5. Reboot.
6. Open GPU-Z and you shall see this hopefully -
7. Now you can overclock it to 880/1375 (the HD6970 speeds) (Note - Every card is different. Some cards may need overvolting to get to 880/1375. Overclock at your own risk)
My Overclocking Update -
This is at Stock Volt.
Temps during BC2 (UPRIVER) -
Benchmark Comparisons -
Metro scores in line with HD6970 (settings same) -
http://www.guru3d.com/article/geforce-gtx-560-ti-448-core-review/18
AvP Comparison -
AvP D3D11 Benchmark Report
* Report Created: 2011-12-15 @ 11:12:39
* Executable Build: V1.03, Apr 19 2010
*DX11 Hardware Detected*
Using Video Settings from file <C:\Users\Jassu\Documents\AvP Benchmarks\Tests\avp_tool.txt>:
Resolution: 1920 x 1080
Texture Quality: 3
Shadow Quality: 3
Anisotropic Filtering: 16
SSAO: ON
Vertical Sync: OFF
DX11 Tessellation: ON
DX11 Advanced Shadows: ON
DX11 MSAA Samples: 4
Benchmark Summary:
Number of frames: 4959
Average Frame Time: 21.1ms
Average FPS: 47.3
Use command-line option '-logframetime' to report performance frame-by-frame.
Scores in line with this -
http://www.techspot.com/review/348-amd-radeon-6970/page7.html
UNIGINE -
Reactions: 1 person
devvfata1ity
Aug 3, 2009
544
18
0
39
NEW 'LOL' BOMBAY
Actually I have a Sapphire 6950 2GB Dirt 3 Edition & it dint unlock as it was having a antilles chip instead of cayman. But since its plenty fast enough without the additional shaders (the extra shaders add max of 3-5% performance), I have OCed it to 950/1450 now. And at these speeds it eats the GTX 580. :D
Jaskanwar Singh
67
7
0
30
chaqli said:
Nice!
And good examples of misleading graphs due to improperly chosen axes.
thanks.
ok, i will change the graphs tomorrow.
changed the graphs and added metro and AvP comparison.
NHS2008
121
35
98
https
Good tut. I had unlocked an MSI 6950 into 6970! Then I oc'ed it to 950/1450@1275mV. What a blast it was!
but I undid the OC as theres not much need for it now.
mrcool63
Nov 4, 2007
868
22
82
another succesful unlock.. awesome:) but dude certain points
1. For some it does not recognize.. in such circumstances switch back, uninstall drivers then switch the bios and reinstall drivers..
2. for some they need to flash the bios with the modded 6970 bios to get it to work..
kuhnas
9
0
0
Good for every .Good tut. I had unlocked an MSI 6950 into 6970! Then I oc'ed it to 950/1450@1275mV. What a blast it was!
Altair
Nov 28, 2010
1,959
41
113
31
Chandigarh
Oh man. I tried everything. But failed.
Has anyone tried it on the 1GB version and succeeded? Please tell me how you did it? Feel free to PM me.
