FS: Others Static TV Wall Mount (200x200 mm)
t3chg33k
Feedback: 73 / 0 / 0
Mumbai
4 out of 5
  1. Bank Transfer
Excluded - at actuals
NA
No
Old TV has gone kaput
Had an old 40 inches LED TV wall mounted in the bedroom by an official Samsung technician and he used this mount. It is a standard 200 by 200 VESA mount that works for most TVs upto 43 inches.
It is supported by 2 points that go into the bracket 200 mm apart and the 2 longer supports act like buffer, so it will work with 200x200 or 200x100 bolt patterns.
Can this be used to mount 27 inch monitor with Vesa Mount ( Model AOC c27g1 ) https://www.aocindia.com/monitors/c27g1.php
Just wanted to update that it was not worth selling it for scrap, so kept it. If anyone wants it, then drop me a PM.
