PC Peripherals Strange Beep sound from Cabinet
Have you OC'ed the system ?? a bad oc can also cause the system to lock up or reboot .. had happened with me once :) also check the RAM for errors with Memtest
Check up on the values for each of the voltage lines (12/3.3/5) of your power supply when this happens. Any of them running lower than the set threshold can also cause beeps (more like a siren).
