Suggest Wall Fan with low noise
Emperor
Juggernaut
Hello Friends,
I have Polar Wall Fan, no problem so far in last 2 years, have 6 yrs warranty.
But makes lot noise when run On and over 3 level of speed.:@
Can you please suggest any Low Noise Level Wall Fan?
I saw a few Indian wall fans and all were poorly made and noisy ... then I found this National Floor Fan for 4K at Mussafir Khanna near Crawford Market. I use it on the table to cool me. :P
It is absolutely silent and has a remote control and has 3 speeds and the front rotates - I have used it for about 3 years now and it has never had a problem - it still runs as silent as the day I got it. I think it is worth the amount I paid !!
Can you give me the Name/Number/ OR some hint (if you remember or can) about the Shop/stall/person?
Can I get same fan from any authorized dealer, as Musafir khana is famous for imported product (but I'm totally dumb to verify and chance to get imitation product is lot)
I got the fan thru a friend who is no longer in Mumbai - I do not have an idea about which shop it came from as the guy delivered it home after my friend spoke to them. If I can find out these details I will let you know. But FWIW from what my friend said it seems the shops in Musafir Khana are more trustworthy then most others. Check with Alpha at Irla - they may have these type of fans too.
I checked at that time at Heera Pana and they wanted 5k for this same fan :no:
Can you give me more detail like model no., name, make etc. I'm far away from 3 places you mentioned. If some details I have, can order through local dealer/supplier.
