Suggestions for good battery chargers for Sanyo Eneloop rechargeable batteries.
BIKeINSTEIN
Herald
I am planning on buying some Sanyo Eneloops (or something similar) for a new digicam. :P
Will be getting a Canon SX110IS or something similar. :)
I have no idea on the batteries or the chargers preferred. :ashamed:
Which ones should i look for- locally and from ebay/Amazon or US/SG? :)
Bikey, Alfa has some good chargers & batteries options. They have chameleon, sony, sanyo high capacity options.
If you want high end chargers nothing beats La Crosse - but you may have to get it through KMD.
Locally though, get something which has individual charging indicators and automatic cut-off. Most of the chargers do not have individual charging indicator lights and you never know whether it is charging or is cut-off. I have a Camelion charger which has individual lights and they change color to indicate full charge/charging and defective. To be on the safe side, I can remove the ones that are already charged although it has auto cut-off. I had bought it long time back from JJMehta when I had got my S2
La Crosse all the way :D eneloop battries are available locally, other batteries with higerrating sitll crap out in a month max! even if u dont use them! I gota La Crosse from KMD long back!
Sanyo Eneloop batteries are one of the best (buy only the batteries based on the eneloop/hybrid technology, if you are buying some other brands).
As for the charger, any decent charger will do. If you are getting it from US, get La crosse charger (one of the best). If you plan to get the charger, get the eneloop charger itself, its good enough. Sanyo eneloop 2 x AA batteries with charger (4 batteries can be charged at a time) is Priced around 1k (MRP).
If in Mumbai, call up JJ Mehta, he used to stock Panasonic Fast Chargers, very small, slim and perfect for the camera toting traveller. Charges my 2100 NIMH units in 4 hrs flat. Charge 4 AA or 4 AAA or any combination at a time. Can charge single units also.
Using for last 2 years now. (Note: Made in japan units, @ 750 odd, with no battery included)
Ask for the camelion fast charger too, I hear they are decent too.
if you can source from ebay us / usa / sg then la crosse is the best in chargers.
it gives you so many options and variables.
i am using it and happy for it.
Guys,
Where i will get Eneloop batteries in pune?? Anyone who purchased from pune?
Not getting in electronic lane in pune :no:
Amazing how many ppl vouched for the La crosse charger, presumably the BC-900.
Well, imma break with you fellas and say i got the maha-c9000. Have to say I was very tempted to get the La crosse but all the horror stories of it melting down and 'cooking' batteries scared me. I was going to get one from the US and there was no chance of sending it back for an exchange or a refund. Lacrosse goes for $45 with extra 'gifts' the maha is ~ $50 with no gifts. So the lacrosse is really $35.
So yes, BC-900 is a nice charger, a little easier to use but the c9000 is the winner here for features & build quality. It has the IEC std break-in feature for new cells, takes about 39hrs to run.
My problem is i don't get that many hrs uninterrupted power :ashamed:
Otherwise i have quite a few issues with the posts in this thread which need to be addressed when i get more time.
But its also 12V compatible so maybe i can hookup a car battery to it somehow failing that a sinusoid UPS, don't want to put the APC-backups on it as the square waves might spoil it.
same as others...sanyo eneloops, but check their manufacturing date first...i found packs in planet M which were 1-2 years old...prolly not a good choice
and ive been using the lacrosse charger from the GO couple of years ago...very satisfied till now
Unless you want a Night Light the size of a Brick. Working on Maha C900 is akin to assembly level programming. Simply selecting a appropriate current for a single cell take around 40 Key press i think.
It is the best battery conditioner/analyzer but not many people buy it cuz of the complications listed above.
BC-900 was being recalled since Jan 2010 but new batches have been introduced in April 2010.
I would still say that BC-700 is the best bet as of now without being too expensive.
A brick that weighs 400gms and the night light can be reduced by placing a playing card over the display :)
If you were in a car and wanted to have charged batteries, then unless the charger accepts a 12V input your're stuck. So here's something you can travel & use at the same time.
If you're using a 2000-2400mah battery, and just want to charge it then stick it in, and proceed to the remaining slots, done. No more presses required, none in fact as first option in the menu is charge and default charge is 1000mA or 0.5C, if you want other then punch it in, i've read the reviews on amazon (NLee the engineer, in particular) that give this impression that its quite complicated, but in practice I don't find it to be that way.
The biggest advantage with seperately programmable channels is you can have different jobs going on different cells at the same time, should you need to.
This is why i looked for forums where ppl with this charger were talking about it, the consensus amongst the clued up over at CPF tended towards the maha.
Here's about as compact & precise a comparison you will ever find between these two chargers.
The seperate thermal sensors for each channel on the maha vs a shared one for all four on the lacrosse is the biggest safety feature i was looking for. I don't want to babaysit the charging and i've got batteries of varying ages & qualities, i don't want to find a smoking mess when i get back.
Right, and i think thats the greatest pity, because its a very attractive looking charger and i would say for most ppl it would be perfect except for the issues it had. Not heard of any problems with the BC-700 but its a slightly weaker charger compared to its predecessor.
Cost wise they are two seperate animals, one is cheaper than the other and you get what you pay for.
Don't get me wrong, I posted this so others would realise there are other options out there and who knows, if there is enough interest, maybe another GO :)
Though your point about voltage is correct but the size of this thing would be a obstacle in achieving the portable functions as you mentioned.
The default charge rate of 1000mA is pretty high i think. Again its very theoretical that High rates decrease the life of battery but still i would want something like 200-500 which is provided by most of the chargers.
I cant comment on the number of steps required to set the individual charging rates as i dont have one. I just wrote what i read from the reviews. Maybe you can shed some light on that.
4 hrs flat means it does 0.25C, does it do any trickle charging beyond the 4 hrs ? or is it 0.5 C with 2 hrs on trickle.
TechHead said:
Picked up a 15 minute Sanyo charger from Bangkok. Quite nice.
Cost around 2.6k with 4x2500mAH batteries.
This is the ultra-fast charger, don't expect your batteries to get beyond 75% capacity with them. Also as its designed for 2500mAH make sure you don't use it with batteries of lower capacity as they will be overcharged, not a good thing and is the #1 killer.
Dunno, its bigger yes, but thats because the designers wanted to have an adequate air gap so that the batteries could stay cooler at higher charging rates. Any avg laptop is much heavier and bigger than this charger yet its never considered not portable is it, so why the hangup :huh:
The battery manufactuers recommend a 0.5-1.0C charge rate. Now what the 'C' stands for is the capacity of the battery, let's say you have a 2000mAh battery,
- a 0.5 C charge rate means a current of 1000mA and it would take 2 hours to charge up,
- a 1.0C charge rate means a current of 2000mA and it would take 1 hour to charge up.
- a 0.1C charge rate means a current of 100mA and it would take 10 hours to charge up.
The same applies of course during a discharge in an app as well, if you run with a constant load and the batteries are done in 2 hrs, your load is 1000mA.
Now whats missing in this scenario is the charging efficiency, upto 70% capacity the battery accepts charge very efficiently, once you cross the 70-75% mark it becomes harder to charge it at higher currents so that's when the 'intelligent' chargers switch down to a trickle charge, say it was charging at 0.5C , the charger would then drop to 100mA for a cpl of hours to increase capacity from 75% to 95%. This is why when someone posted here earlier that with a 1-2 hr charge rate he got fewer pics than with a slower charge rate.
Now a lot of chargers out there are 'dumb' chargers, they work with a timer and are very small as there is nothing else to detect an end-of-state charge. They tend to be gentle taking anywhere from 2 hrs to 16hrs and this is primarily a 0.5C - 0.1C. What needs to be realised is these chargers should only be used with batteries of the same capacity they came with, if you get a charger with your new 2300mAH or higher batteries, you do not want to use it with older sets of lower capacity as it would be overcharging them. This is where the flexibility to set the charge rate of an intelligent charger comes in.
When a NiMH rechargeable battery approaches full there is a slight drop in voltage across its terminals, the higher the charge rate typically 0.5C -1.0C the more noticeable it is to a charger looking for this sort of drop. This is known as a negative delta V, the maha uses this method to detect a battery is full and is why they recommend a higher charge rate not to go below 0.5C on charge rates. The BC-900 uses this as well too.
There are 5 modes, if for some reason you want to use 100ma either to charge or discharge or cycle for all four then there are 40 presses. But the buttons have good feedback and response is almost instant so you can punch those in quite quick.
adder said:
@blr_p
Where did you buy it and what was the damages
Had a friend bring one over from the US, it worked out to $58 shipped to his place from thomas distributing.
Reactions: 3 people
^Old thread - I've got a MC9000 as well. Excellent charger. One of my new Eneloops refuses to go above 200mAH. Any idea why?
