CPU/Mobo System Lag/unresponsive, I can't figure out what is the real problem ?
rahulyo
Contributor
Hi friends ...
I facing problem with my system from last 10-12 days.
Problem :- System boot time increase (OS Boot Time ) , System Lag/unresponsive , Applications take more time to run (Sometime not run),Games stuck (for a sec).
Do :-
1.Reinstall all components (PSU,Mobo,RAM,HDD)
2.Reinstall windows 7 (32 Bit)
3.Install new Drivers
4.GFX drivers (try 10.4 to 10.7)
Need ur help guys .
Re: Help ! System problem again
run chkdsk and then defrag the hard drive.
also remove unnecessary programs/services from the hard drive and startup
check for a BIOS update as well.
Go to msconfig and set the boot time affinity to 2 cores.
Does the numlock key toggle when it is unresponsive. Run a full virus scan / spy ware detection module(s).
Same as above.
Uninstall all drivers, use the driver sweep method. Put on 10.5. Put this problem may still persist till the firs two are resolved.
What system temperatures are you getting. Any OC..?
prashantrana said:
did you defrag ?
also how much free space is available in each partition.
Yes
Free space :-
C - 28.3 Gb
D - 48.3 Gb
E - 26.7 Gb
F - 23.0 Gb
as said above check he temps and scan for viruses and adware.
Did you install something after which the problem started ?
also have you updated windows ?
Done. No effect.
Unresponsive means I can't click on any icons,taskbar(For 1-2 min .This happened randomly.).I check my PC using KIS 2010,No virus/spy found.
Reinstall drivers using Driver sweep method.Install 10.5
Done .No effect.
Everything is at stock.No OC.
Temp : - 30 @ Idle ,48-50 @ Load
Switch to the i5 system you were talking in the other thread.
i5 for what ? I dont think your current cpu is a bottleneck. I think the problem could be that you have just 2gb of ram maybe.
Can you see what task manager is showing -- I know it will be difficult to check, but try if you can. What is taking CPU resources the most..specially when the 'hang' happens.
I attach a pic of task manager Pls check.
[/URL] Uploaded with ImageShack.us[/IMG]
how much virtual memory are you using. Is it custom or system managed ?
also if you can check your event viewer (windows logs) and see any errors showing up.
Try doing these
Install CC Cleaner and perform a normal cleanup and registry cleanup
Do a complete virus scan (Which antivirus do u use )
Run thorough chkdsk to check for HDD errors
asingh said:
Yes, the page file should be 1.5 x hardware memory.
Page file / Virtual memory - 2047 MB
ronnie_gogs said:
Try doing these
Do as u say .Clean registry using CCleaner
Check for virus and spy using KIS 2010.No virus/spy found.
Also run chkdisk.No error found.
Disable virtual memory completely
Check the performance. Don't do any heavy duty stuff.
You can also add a USB pen drive as ready boost. Preferably 1 GB plus.
