R rokindotnish Inactive Contributor May 8, 2011 #21 @ CA50: there are no physical switches on the system.... ... I've stopped almost all apps from msconfig.... but how can "Force Shut down" be removed?
CA50 Forerunner May 8, 2011 #22 "Force Shut down" appears when some application is running while you try to shut down your system. Have you scanned your system?? Its seems to be infected
R rokindotnish Inactive Contributor May 8, 2011 #23 @CA50: yes, i've done a full scan, AVG internet sec 2011... it only found some keygens and cracks.... no virus found..... wat 2 do....?
