Orient Tab Fans Are good.Can someone suggest me a cool table fan which is as quiet as possible? I have a Havells fan right now and its noisy as hell. Bought it locally so can't be returned.
This seems good but area of effect looks very narrow.https://www.amazon.in/Crompton-Air-Buddy-Kitchen-Black/dp/B07RK48S37
Bought this for use in the kitchen. This has minimal noise, and may suit your requirements.
I don't mean noiseless but it shouldn't be loud. My current fan is unbelievably loud even at lowest speed.I have a oster tower fan bought from Amazon few years back. Very less noise compared to a table fan. The air throw is 8 to 10 feet with high speed. I'm not sure if there is any complete noiseless table fan.
[/URL]Buy Russell Hobbs RTF 4800 Tower Fan with Remote 48 Inch (White) Online at Low Prices in India - Amazon.in
Amazon.in: Buy Russell Hobbs RTF 4800 Tower Fan with Remote 48 Inch (White) online at low price in India on Amazon.in. Free Shipping. Cash On Deliverywww.amazon.in
If budget is not your constraint you can look at Dyson bladeless fan. Also you can check out Russel Hobson tower fan which is similar to Oster tower fan.This seems good but area of effect looks very narrow.
Yes. The area covered is a little narrow. It has an auto swing mode that can mitigate this a little. If it is going to be for a single person, it should be more than sufficient.This seems good but area of effect looks very narrow.
I have orient one which is plastic blades. normally silent if used in first 2 mode. highest (fastest) mode will ofcourse make noise. its an table fan, not an ac where the fan is outside your houseThanks I'll check it out.
My first search on amazon says its noisy lol. What fans do you guys use?
Also metal blades or non-metal? My current Havells has non-metal blades.
Mine is loud even in the first level. Level 3 becomes maddening.I have orient one which is plastic blades. normally silent if used in first 2 mode. highest (fastest) mode will ofcourse make noise. its an table fan, not an ac where the fan is outside your house
are you kidneying me ? 40k ka fanIf you got the cash try a Dyson table fan.
I haven't bought it.Seems I am late..
Perhaps your fan making noise is an indication that either its bearing has conked off or it needs some lubrication. Just a thought.
If you think the noise is the only reason to get a new one then perhaps show it to local electrician.
