heres the story
please please ..read the whole story..in order to understand the problem..and if possible post any solution that comes to your mind )
i had previously modded a Non-T082 PSP on firmware 2.60 using just the software mods. ie- the downgrader and and Custom firmwares.
i used the awesome guide posted by Spacescreamer and a bit of research on google..
everything went perfectly ..and it was done.
now...another friend got a PSP ..which was on firmware 2.82 and ..a TA-082 motherboard ie- IC 1003..
so software modding was impossible.
the only thing possible was .modding using the pandora battery or ..by using the GTA unpatched UMD..
as i already had the earlier modded PSP with me ..i though of creating a jigjack battery and magic memory stick kit..(ie-pandora battery )
i used dis guide to make the pandora battery :
Super noob guide to making pandora battery and memorystick - MaxConsole Forums
everything went perfectly..i was sucessful in making a pandora battery ..
and the magic stick.. using the already modded PSP and the new unmodded PSP's battery.
then i inserted the magic stick and pandora battery in the PSP to be modded..the pandora battery program started with the green and ornage light... i got a message
press X to downgrade the PSP to 1.5
i pressed X, it started some extracting files. and then suddenly i got the message..
Battery charge should be more than 50 %..and the PSP reboots..
after that every time i tried using the battery i got the same message..so even tried charging the battery for 3-4 hrs..but still the same..
so in the end i converted back the pandora battery to normal battery using the pandora battery creator in the modded PSP..
and i was sucessful in doing so by converting the id storage number to.
x012345678(something like that)
but then when i tried using the battery in any of the PSP..
the PSP didnt startup..as the battery was totally discharged..
so i connected the DC adapter for charging..
the orange charging light came up..
the light was there for 10-12 seconds..and then suddenly the charging stopped i tried starting the PSP with the battery it didnt start.
i connected the external dc adapter and the PSP booted
i went in system settings ...and saw battery status
this is what i see :
this repeats every time i turn off the PSP and try restarting it ..
orange light lights up for 10-12 seconds..and the nthe battery stops charging showing charge complete but in reality..the charge is 0 %.
theres no problem with any of the 2 PSP's or the charger...as i tried charging the other PSP..its working perfectly...
i dunno whats wrong with the battery ...but i googled..and dis some research..
this is what i got..
MAXCONSOLE - Playstation 2 Playstation 3 Xbox 360 Nintendo DS PSP Gamecube Nintendo WII Revolution - To the MAX!
looks like a similar problem.expect in my case battery starts charging for few secs and den stops ..!
i tried shorting the battery ..as the solution given in above link...but still its the same..
i even kept battery out of the PSP for 1 whole night and tried..but still the same..
then even kept it in the PSP and connected the charger for whole night..but still no charging !!
now i dont know what to do..
i still have the 2 PSP's working perfectly ..and but only the 1 battery is crashed..
i want to bring it back to life...
so please help me out guys...
i just hope that the Battery is not dead !!
cause..da worst thing ..is its not my PSP..but a frnds PSP..though he wont mind..as i had already warned him about ..the consequences..
but me affording a new battery is almost out of question !
thanx in advance..
under 'battery information' the charge level shows as 0%, but (even plugged into the powr source) the battery status says Charge complete, hours left says -, and power source says external, when the external power source is disconnected, the psp shuts off instantly.
thanx in advance..
