@op, read my helpfull tips post?
hope you have done atleast one of these mentioned in there:
1: In your antivirus / spyware/adware program - set them to ignore scanning the download folder.
2: Make utorrent append !ut extension to the downloading files. Its in Preferences> General.
3: Force recheck the torrents and then start them.
4: Disable KIS if you get the error even after adding the download location to its exception list. Uninstall it and use Avast av if possible.
Also you can try copying one of the incomplete downloads to another location (maybe another hdd if possible), change the download location of that torrent by right clicking on it and > set download location. point the download location to your new directory. If it completes without errors, copy the rest of the incomplete downloads to that new directory and make it the default download directory in utorrent settings. You will have to manually change the location of the already downloading torrents.
