Here is a tiny review of this PSU,
The Box,
Features,
Contents,
The PSU,
The Ratings,
The internal circuitary is cooled by a 120mm Fan,which means it will be very silent in operational mode.
The Molex connectors are a bit different,
The ATX2.0 Compliant 24/20 Pin ATX Power Connector,
Native PCI-Ex Power connector is very helpful these days,
The Usual SATA Power Connector,
Conclusion,
This is a very good PSU.THe build Quality is nice, feels solid,it has sleeved cables.
The sleeved cables really help in cable management,hence helping in maintaining optimal air flow.
The PSU comes with 3 Yrs. Warranty which is very good, and helpful.
The pricing is in the range of Rs. 3,800-4,200/-
The price really is very good for a decent product like this.
Unfortunately i didnt have the time to install it and check the actual voltages,the PSU delivered.
I will do that as soon as i get time.
Sorry about that.
Overall a good product at a good price, definately a smart buy if you decide to go for it.
The Box,
Features,
Contents,
The PSU,
The Ratings,
Conclusion,
Sorry about that.
