This is gonna be some rogueish beauty build.
Actually, the plans are all changing. I started reading reviews and started gaming again on my brother's PC and I don't think the mini-ITX will suffice me. I am now looking at either micro-ATX or even an e-ATX board ......
Do consider the $300 odd 27inchers from Korea you can get off of EBay. I just got myself a similar PLS panel and I'm very very happy with it. Will be posting impressions and pictures this weekend.
As for the display, do consider this option:
There are a few others who've gotten these Korean 27 inchers off-lately and they have all been content with the IQ of the display and the build quality. For three units, this might end up cheaper than the Dells but as it holds with any other piece of electronic stuff - reliability might be a gamble! The inputs are also fewer than the Dells IINM.
@viralbug - some inputs from your unit please?
Hmmm...... (was silently waiting for this)
I chose the CM-Storm Stryker way back in Sept-12 (there are other beauties out there too) & air-cooled with the Noctua & it is truly silent (although everyone was surprised why I did not go the liquid route). No regrets. I have 7TB of HDD's inside and there is still room for another 3 more HDD's (which I plan to add after a year or so ...when 4TB or more prices stabilise). My 4 ram slots are occupied with 16GB, so I am screwed there (will have to swap all of them in case I feel the need for 24 or 32GB in future). All this is connected also to a 47" LED via HDMI for gaming (other brats use it - gaming) and watching movies, otherwise I have the U2312.
Now your overall build is even shaping better with a 3-monitor setup etc. Look at the 'larger' picture & do not have any fixed or rigid plans (a budget of your type should not be wasted).
How do you find the 47 incher for gaming.
I really thought that having a big budget would make it easy but it is actually more difficult to make a choice now.
Add to that, that this build will be liquid cooled so I have to make choices keeping compatibility and color-scheme in mind.![]()
It's awesome... gives you a true cinema feel. And I have only a Asus 660Ti - Direct CUII [not a 670 or sli rig
However I would never recommend this as a primary set-up. One need'd to have a normal 22-24" monitor for routine day-to-day work.
Did you also factor in the 'ambient lighting in your room'![]()
I really wanna go for the large screen + cheap monitor combo.
1) Even though the screen is big, it is still just 1080p which means any good single graphics card(7990, 780, Titan) will be more than enough for ultra settings. Furthermore I can just upgrade the card every year or so and be done with it which is not possible in an SLI setup.
2) I hardly play FPS in which the lag can be an issue.
3) A large screen is not only good for gaming but you can enjoy movies and most importantly for me - football matches in HD.
The LG TV I looked at is 120Hz so that can be a good thing as well. Though reviews say that it doesn't have the option to change the refresh rate like other TVs have and I will be stuck with 120Hz which make the HD movies look a bit odd. It is available for 48k.
