Nope, the specialised GPU coolers are one of the most expensive components of WC setup.
even if you want to cool just the GPU be ready to spend something close to or more than $200.
If you are ready to improvise and build a system from just imported block and locally available pumps and rads then it might just fit the budget.
And ya, moving system is considered as biiiig NO NO with WC setup.
