WiFi extender that plugs in to a power outlet
RadarHz
Something like this is what I'm looking for. I'm on a mesh wireless network and I want to use the extender to boost signals around my area. Max 3 devices will be connected at any given time.
Suggestions? Obviously I will try to look at options as cheap as possible. Open to second hand purchases.
Whats the downside in going for a cheaper option like this:
Compared to a more expensive option like this:
What am I missing out/not getting?
Brand name , also both are a single 2.4ghz repeater.
If your router is 5ghz you may wanna consider a 5ghz repeater
Also if you are already on a mesh you also get small mesh pluggable nodes, you may wanna consider that too
TP-Link AC750 Wifi Range Extender | Up to 750Mbps | Dual Band WiFi Extender, Repeater, Wifi Signal Booster, Access Point| Easy Set-Up | Extends Wifi to Smart Home & Alexa Devices (RE200) https://www.amazon.in/dp/B00KXULGJQ/ref=cm_sw_r_cp_api_glt_fabc_62XGA3Q0HEHYD02FKQPP
If I may ask/add to the thread, Does this one work well? And is it worth buying the AC750 pro fo a couple 100 bucks more? Only difference is the pro has a couple of antannae.
