axis.meister
Discoverer
Hello friends,
It seems that the Transmission power of my Canvas HD(running SamHD v3.2) WiFi chipset is low, because sometimes I cannot connect to my Wifi router (Asus RT-N13U with DD-WRT) from certain places in my house, while I can connect from the same place using my tablet or my laptop or my brother's O2X. So I was using this WiFi TX power management utility while I was using the stock ROM, and it seemed to work(sometimes).
Now I am using the SamHD ROM and it does not have iwconfig that is used by this utility. I know I could find a workaround by adb'ing iwconfig into this ROM or something else, but before I do that I wanted to know if any of you use any WiFi Power Management app and if they actually work for you?
Any suggestions for alternate tools which contain the iwconfig/iwmulticall utils are also welcome.
link to app I use https://play.google.com/store/apps/details?id=rubberbibpepper.WiFiTxPower&hl=en
Rgds,
ax
Rgds,
ax
