8260NGW Wireless Wi-Fi + Bluetooth 4.2 Card NGFFCard
Looking for same or similar card.
Far better -
https://techenclave.com/threads/intel-ax200-wifi-6-card.226675/
Thanks bro, but Sorry don’t have budget for this. Max I wanna spend is 1k.
I might have this exact same model @@chetansha will let u know
Thanks bro. You msged at right time, I was about to buy
https://www.amazon.in/FENVI-FV-AC1200S-Bluetooth-Antennas-Compatible/dp/B0DVPS6Z1D/
Thread ‘Intel 9560NGW wifi card’
https://techenclave.com/threads/intel-9560ngw-wifi-card.227798/
Check this out, it’s right around your budget.
Check for compatibility though.
Will check. It needs to fit in this adapter.
Won’t suit.
Are you interested in [Intel® Dual Band Wireless-AC 3168](’
https://www.intel.com/content/www/us/en/products/sku/94854/intel-dual-band-wirelessac-3168/specifications.html
). However the speed in lower than your requirement. Rs. 600 shipped
And Dell DW1810 Rs. 400 shipped
Hi, sorry nope. I would prefer same or better. Thanks man.
Mods, pls close this thread. Purchased one card from @@StygianClaw
