Hi
I am trying to assemble a computer and need some advice :
Computer will be used for gaming, i would liek all the new games to work decently well.
However my budget is a bit tight around INR 26,000/- without monitor{i will be buying a 22" monitor seperately a little later}
I was looking at -
CPU : Intel Q8400
Motherboard : Gigabyte GA-EP45-UD3L P45 Motherboard
Graphics Card : ATI Radeon 4870 1GB
Memory : 4GB [any suggestions what make i should buy?]
Cabinet with power supply : need suggestion
HDD : 1x500GB SATA will do for now.
I am thinking on lines of the above configuration and i am overshooting my budget, do you see any place i can reduce costs with minimal performance degradation?
Plz wait for 1156 socket boards to be out with proccy. Else ur system will get outdated within 2 months. Not to mention DX 11 GPU is coming out in 15 days.
If u cant wait go for an AMD config.
PU : Phenom II X 4 920 9.8k
Motherboard : Biostar 790gxb A2+/A3+
Graphics Card : ------
Cabinet with power supply : CM RP 460w/ GP 650
okay i am going to rephrase my question.
Suggest me the best possible config for Rs.25,000/-
Price does not include 22" monitor that i will buy later, hard disk, keyboard, mouse[as i already have these]
Open to both intel and amd.
Will not be overclocking(do not know how to)
Great, thanks so much guys.
I will probably see if my computer guy has all this tomorrow evening, till then i am open to more suggestions.
Also any shops/dealers in bombay that you would want to recommend, always welcome.
And once again guys, thanks so much.
Better to get the Asus M4A78 plus. has better onboard audio, more ram slot ( 2 on biostar and 2 on asus ) which is very good if you need to add more RAM in the future.
