Best 32 inch FULL HD TV
Here is one just launched on 28 April 2025, it is a smart tv.
Buy 80 cm (32) HD Smart TV UA32H4500FUXXL | Samsung India
You can not spot that this is a 50Hz tv anywhere on the samsung site itself.
If go on alternative links like, it’s clear that it is 50Hz.
Samsung H4500 32 inch HD Ready Smart LED TV vs Samsung H4570 32 inch HD Ready Smart LED TV | Smartprix
https://youtu.be/qNXeOSaqHzI?t=330
On samsung site I can’t even download the user manual of the TV, that usually has the specs and stuff.
Very less options on this budget. maybe check the TCL S5400A 32 inch. TCL provides 3 years warranty for their TVs so that would be a safe play
One of the rare options. Go ahead if you still want a 32” 1080p TV. Considering many people use 27” monitors, heck even 32” monitors, my statement on size still remains.
The thread has moved fast.
I think 50hz and 60hz shouldn’t matter. All screens should be 60hz. Screens will default to 50hz based on location they are sold but will still accept and display 60hz.
There will be no perceivable difference between 720p and 1080p for 32 inch, unless you are desktop close.
I completely agree with omega44-xt but OP has made it clear he wants only 32 inch. Don’t want to sour his purchase.
Yeah can’t go bcz of space issue and distance issue…a specific issue u can say…otherwise I understand that 43inch full hd or 4k makes sense but can’t keep it at that place…too big for my case…
So thank u all for all ur inputs and suggestions…
LOoks like will go and see in corma, reliance digital and other multi brand store and see the quality and than finalize…
Most probably will go with TCl with 3 years warranty and full hd and 300nits and 24w speaker..
Will also check Mi a pro model and lg and samsung in the store so that can see the quality difference and decide accordingly…As all these are 720p but still will see in real in store and finalize..
Need a 32 inch Smart FHD TV from brands like LG, Samsung and Sony?
Budget under 15k
This TV will be used in a village and is for viewing soap operas and OTTs by elderly people.
So suggest accordingly. Thanks.
OP - If you are going to go see them offline. Do check viewing angles. Beyond the obvious this is where premium will have its edge. For me this is where the lower tier models lose out.
Again, my experience and info are dated.
Does it means VA panel and IPS panel diff will come into play in viewing angle which u are taking about? @The_Eternal_Guest @Heisen
Or
u mean to say even if all are ips display than also there will be diff in viewing angle depending on quality ??
No full HD tv from Samsung and LG, I guess Sony too under 15k.
Then for how much will they come for? I prefer LG mostly because my father is using a 43 inch Smart TV since 3 years and its working great until now.
VA / IPS will be huge difference.
There will be much harder to spot.
32 inch FULL HD TVs are bad category, there are next to none models listed on Samsung and LG site. On flipkart/amazon those are old stock, 2022, 2019 etc.
It’s either go for 32 inch HD models around 20k or go for 43 inch 4k models starts from 30k.
Which will be better in what scenario?
Which should we go for or depends on requirement?
If yes than on what basis should I select va or ips tv?
IPS has better viewing angles (officially it is 178 degrees) & colour accuracy while VA panels have bit lesser viewing angles & colour accuracy but deeper blacks/better contrast which is better for watching movies/videos. It all comes down to your personal preference then because nobody is measuring angles to sit at 165 degree to watch TV (where a IPS panel might look a bit better than a typical VA panel).
No bro.. my wife got a samsung 32 inch fhd under 15k from local reliance. Sometimes they aren’t available online.
That’s why I was recommending also to check out local outlets
Old stock that launched in 2019/2022 is available. I later found out.
@mysticrainman Can you get the model number for that full hd 32 inch samsung?
@OMEGA44-XT can you mention the model no of the tv your flatmate got?
Don’t remember & doesn’t matter. Its successor will be the current cheapest Hisense 43" 4K, which is E6N. E6N seems to be IPS whereas earlier it was VA.
Hey sorry I couldn’t reply earlier. The Model is UA32H4560FUXXL
