So here is what I have come up with, I would like to get people’s views and suggestions on this. I initially thought of 35K but now willing to go upto 40K. I already have my friend’s Nvidia geforce GTX 1050 ti for graphics and the rest of my picks are below.
Also I am thinking about getting all these in Vedant Computers (Online).
That is indeed a very badly put together rig. I’m not sure who suggested you all these, but that guy is definitely not your friend.
For example, why you would get a Ryzen 3100 Quad Core for 10K when you’re getting i5 9400F Hexa Core at the same price?
And there’s the PSU, RAM and all. You haven’t even selected the cabinet.
Moreover, I’d suggest avoiding Vedant Computers. They are the biggest scalpers on the market and throughout last year, their prices were looting customers.
Instead, opt for any other reputable store. My personal suggestion would be MD Computers.
Here’s the complete rig that I put forward for you at the same budget from MD Computers:
Core i5 9400F - 11500 INR
Galax H310M Motherboard - 4550 INR
Teamgroup Vulcan Z 16GB DDR4 3200 MHZ RAM (16GB x 1) - 7500 INR
Teamgroup GX1 240 GB SSD - 2800 INR
Toshiba P300 2TB 7200 RPM HDD - 4870 INR
Antec VP550P 550W PSU - 3100 INR
Gamdias Argus E4 RGB Cabinet - 2950 INR
Total - 37,270 INR
Attaching a cart screenshot. Do let me know if you have any questions.
Agree. The config is not ideal for that price. Ryzen 3100 is a mediocre CPU and on top of that you are spending 9500 for a motherboard that will be too much fo ryzen 3. A320 boards are more than enough for Ryzen 3. You do not need B450.
I had Ryzen 3200 + Gigabyte A320-DS3H + 8GB of DDR4 (adata xpg 2800MHz). Open half a dozen tabs in Firefox/Chrome and whole system would start lagging.
Get at least 3500 6 core chip. For motherboard, check ASUS Prime B450M-K for 6.6k (a wifi card barely costs 1k these days and there is no need to pay 9.5k for built-in WiFi).
If you are okay with Intel, check 10400F based configuration. This chip costs around 14k but it comes with 6 cores and 12 threads. Build your desktop around this CPU and you will not be disappointed.
**Intel is the VFM midrange king right now. (who thought that AMD would be the performance king and Intel VFM king?).
SSD: **120GB SSD is waste of money. Get atleast 240GB SSD which costs just 1k more. If budget right now is a concern, get the HDD alone for now and use Windows on HDD. Accumulate up to 5k and you can get MX500 512GB SSD (or similar). HDD: Stay away from Seagate and other HDDs that come with puny 2 year warranty. Look for models with 3 year or 5 year warranty. Failure rate is too high for these new HDDs. PSU: Corsair VS series is not really Corsair. Check competing brands like Antec.
You really should try and get two sticks of ram because dual channel does make a noticeable difference.
Also for the power supply, try and get a CX450; best PSU in its price range, 5yr warranty & top of the line internals(either that or the MWE 450 Bronze V2).
Corsair has dozen lineups and VS is their entry level for those who want brand Corsair. There are better models from Antec that costs less and works better.
A pcie 1x or usb wifi is very good. They work as well or better than wifi on low cost mobos. Check models from ASUS for pcie wifi that also has built in bluetooth (use bundled cable to connect the card to bluetooth header on mobo)
MSI B450M BAZOOKA MAX WIFI, i.e. the motherboard originally mentioned by @@the_beginner comes with a M.2 E key Wi-Fi+Bluetooth module. Agreed, the factory-installed Intel 3168 module is more of an entry level offering, but it can easily beat USB based Wi-Fi solutions. Moreover, it is possible to upgrade to a Wi-Fi 6E-based Intel AX210 by just replacing the M.2 card. I’m not necessarily suggesting to stick with this mobo, but paying for the M.2 E key slot is worth IMHO.
PCI-e based cards, as suggested by you, is also better than USB-based solutions. But there’s no point to block a full PCI-e slot when you can have a much smaller (and upgradable) module by utilizng the M.2 E key. The M.2 2230 form factor is sufficient to hold the integrated Bluetooth chip as well.
It is worth mentioning that newer Intel platforms often deploy CNVi modules, which are dependent on the host CPU and can’t be upgraded easily with an aftermarket module. Do read the motherboard specifications very carefully before purchasing.
i5 10400f is a decent processor for the price and an worthy alternative to the Ryzen 5 3600.
Antec makes great PSU for the price, reviews for the Galax products are not very positive so I would usually avoid them, Teamgroup products seems to be making reliable products.
Well it’s not a bad idea to stick with 8GB for now but considering that you can get a G.SKILL Sniper X 16GB (2 x 8GB) DDR4 3600 for ₹6,996/- you should probably get these 16GB sticks. [ Buy G.SKILL Sniper X 16GB (2 x 8GB) DDR4 3600 Desktop Memory F4-3600C19D-16GSXKB in India At Best Price]
That power supply is not particularly good. Try to get an MWE 550 Bronze v2 (though the 450w one is plenty for your build) or a Corsair CX450 depending on availability.
Thanks for that bit of info. I’m not the OP but having WiFi on the mobo wasn’t really a priority for me since I preferred a wired connection, but always thought I could get a WiFi card if needed. Blocking a PCIe, yeah that could be a concern in mATX but less so in ATX I think, depends on what other cards the they plan on having. For example, I’m planning to get an ATX board and will only have the GPU and an M.2 SSD at most for my current need, so there are extra lanes for whatever additional card I might require later.
But how does one replace the M.2 E-key WiFi card on a motherboard? Are these available for purchase here and are they cheaper than PCIe cards? I thought PCIe cards offer more benefits but I need to check more on this M.2 vs PCIe WiFi cards. What I gathered from quick googling is that PCIe WiFi cards are M.2 cards with an M.2 A/E-key to PCIe adaptor. I could be wrong though.
I’m having a hard time finding the M.2 E type socket on the said board - https://www.msi.com/Motherboard/B450M-BAZOOKA-MAX-WIFI/Gallery#lg=1&slide=1
I would suggest u go back with your ryzen build but only if u gonna upgrade your components (cpu mainly) frequently, the only change I’m gonna suggest you is getting a b550 motherboard instead of a b450.
Now if u gonna go ahead with intel I wud suggest u buy i5 10400f and not i5 11400f . The reason being the price. i5 10400f can be bought for 12-13k but the price of i5 11400f is 17-18k(not justified). your cpu choice between 10th or 11th gen also depends on your gpu upgradation .11th gen is measurably faster than 10th gen but price is to be considered also . 10400f will support upto 2070 or 3060 easily 11400f will be about 10% faster give or take.
Also don’t buy a motherboard cuz it has wifi it’s the worst reason to buy one . For intel buy a h410/h510 motherboard and get a 1000rs wifi dongle which has usb extension cord it’ll give u better wifi trust me , I have a tp link 1000rs dongle came with a 3 ft usb extension and gives me speed upto 150mbps(better range than my inbuilt wifi)
-----If u get 11400f for 15k buy it but I doubt ull get one for 15k----
If u don’t mind me asking what are u planning to use this Build for and what components u wish to upgrade in future if any
At first I thought amd has the best cpu in my price category (13k to 17k), but after comparing some cpu’s in cpuuserbenchmark.com I came to know that 11400f performs great (but in versus.com ryzen 5 3600 is better than 11400f, can someone clarify this point?) , that’s why I chose Intel. I won’t upgrade anything except SSD, ram, graphics. B560m is the motherboard that I chose which has 2 m.2 slots, type c port too. But I’ll check whether a non wifi one is available (if u know please suggest me). I have just now started my enquiry about the prices in my local and one said that I can get 11400f for 14k (but not sure) . I am also planning to go all SSD(1tb for now but I’ll buy another 1tb after 6 months) and totally removing the hdd. What do u guys think?
Some of those benchmarking sites are biased - specially towards Intel. Now about actual performance, you can rate them as 10400F < Ryzen 5 3600 <= 11400F in non-gaming scenarios. Difference between Ryzen 5 3600 and Intel i5-11400F is marginal. However in gaming, i5-11400F is quite ahead of R5 3600 and tries to reach territory of R5 5600X. May be this review can be help you understand better rather than plain benchmarking sites. About AMD and Intel, both current sockets are towards EOL. hence, if you are not going to upgrade core components in future, get whatever best offerings are available for your money.
About storage, yes you can go for all SSD storage. I was using 256GB NVME + 2TB internal HDD + 2TB External HDD; my current setup is 1TB NVME + 2TB External HDD. Contents which are not frequently accessed can be put on an external HDD. Depending on an individual 1TB SSD could be okay for system, application, some file storage and few games.
Mostly gaming (1050ti for now, might upgrade after a few months), rarely MS Office and browsing. Can’t believe these benchmark sites these days. 11400f is ranked 20th and ryzen 5 3600 is at 108th in cpu.userbenchmark.com (Please click the green human to continue - UserBenchmark)… but in versus.com ryzen is better bcoz it has better clock speed. I actually wondered how intel is even in 20th position. Both are 6 cores, 12 threads and ryzen has better clock speed, how is intel a better one / more or less same here?
Planning to buy a mechanical keyboard, decent mouse, 144hz monitor too…
Don’t use those sites man, userbenchmark is well known to be biased towards Intel and versus is just not reliable. Look at reviews by actual tech reviewers. For example, something like this: https://www.youtube.com/watch?v=3T--8nA_dBo or maybe you can look for a more in depth review.
