Hello, everyone. I need help buying a stock android phone under 20k
This is agastya and I’m new to this forum.
I’m looking for a stock android phone under 20k for my sister. Her primary purposes are daily use and photography and decent battery life. She prefer a phone with a snapdragon processors.
Thank you.
Check moto models
I was thinking of buying the moto edge 50 fusion. But it’s out of stock on Flipkart
Moto Edge 50 Fusion is not out of stock on flipkart.
It’s next sale date is 5th June 12PM.
Moto is no longer exactly stock, they have added their own embellishments.
If that is OK, you can also consider the Nothing 2a in sales.
Lava too is close to stock.
Hmm.. what kind of bloatware they are loading these days ?
they call it Hello UI or something like that. NP is cleaner, so far…
What about Nokai?
they are no longer having that license to use the name, they call themselves HMD. They have always over-priced themselves out of the market.
nothing really, what they have added is actually useful. moto has never been stock *stock *android, they have always added their own touches
Nokia is pretty much dead for now. HMD has decided to launch their own line of phones and basically abandon the brand, at least in smartphones. They do still have the license afaik.
Good thing ig. None of the Nokia phones by HMD were ever in my consideration. Nokia deserves better.
That is fine. I got the impression that they started to add bloatware apps. I am looking to get a Moto to replace my mom’s old Nokia.
They have a few games things and a few ecommerce things that are basically shell apps, you actually have to opt in to install the actual apps. Whatever is installed is pretty easily removable via settings>apps itself, without adb, and it’s ‘uninstall’, not just disable or something.
There is some bloatware but it’s very much more restrained than something like what samshit does.
They have decent phones specially if your budget is above 20k, they have some bloatware specific apps but shit that’s actually useful, I’m on an edge 30 fusion so I’m not sure how the newer series hold up (bloatware wise),but I haven’t heard any complaints about it in my circle.
One major con for me is lack of accessories like a back cover, tempered glass and the curved display that moto is shoving down our throats with the newer series. you might want to look into that
If u can increase budget above 20 and maybe combine a sale w/ bank offers, go for nothing 2a. Most obvious and best choice. Else, look at Lava’s phone, Blaze Curve (i think)
Avoid Moto as I have seen a lot of bad reviews of it, and buying moto isnt worth it at this price point.
OP got BANNED!!! why ?
Spamming for market section.
