HIS Radeon 5670 and Sapphire 5670
hi I’m really confused about the best in HIS radeon HD 5670 512 MB and sapphire 5670 512 MB
i heard that sapphire is best in claiming warranty and all… but i do’t know any thing about HIS. i was decided to buy the sapphire 5670 before.. but just now my friend tell me about HIS. friends please tell me about the performance details of HIS and sapphire and which is durable and which is best. which one should i buy. and main thing is warranty and all.. want to know which is best in that too
Advances thanks to all
can u tell us ur budget? i think we can suggest u something better than 5670 after knowing ur budget… :slight_smile:
my budget is 5000
my configuration is giving below
M.B → Intel DG31PR
PRO → Intel E5400 2.7mhz
RAM → Kingston 2BG
PSU → Blue Storm Pro 350
HDD → 320 GB Samsung
LG 15 inc CRT Monitor
Awwww…Corrected that for ya…:slight_smile:
i think With this setup u Will not be Able too unleash the full power of 5670…
A 4650 should suffice
Check this - eBay India: GRAPHICS CARD XFX ATI RADEON HD 4650 1GB (item 160530276011 end time 17-Jan-2011 14:44:23 IST)
Use A 500 off min 2500 Coupon and u get it for Rs 2200 :slight_smile:
Go for a ATi Radeon HD 5670 if it falls in your budget but best bet for your money is the Sapphire ATi HD 4670 1 GB card for ~ **3.7K inclusive tax in Bangalore **:), Happy gaming.
MHz or GHz. :blush:
I think a HD5670 will be a bit more future proof if he doesn’t intend to upgrade frequently.
Go for HIS Radeon 5670.
thank u all… for sharing ur valuable suggestions…
sapphire 5670 512 MB is not available now a days i’m searching for it.. is that product is available nw.. HIS 5670 is superb in it’s appearence
Yes the custom cooler is a treat… grab the HD5670, but I think if you can wait a month or two, it would be nice.
AMD has just launched the mobile 6000M parts, and there’s a 480 Shader graphic card(based of HD6800 barts) which is sure to be coming to desktop as the replacement for HD5670. So you know, you could wait a month or two.
If you do not have a good PSU(ie., using the generic PSU that comes with the cabinet) then i would suggest a HD4670 ~ 3.7k and a good PSU like the FSP SAGAII 350w ~ 1.5k.
Edit: OP already have a FSP Blue Storm Pro :ashamed:
5670 would be good,i dont think you may need a good psu for it,and if price is similar,id say go for the his ,because they have 3 years warranty and while sapphire has two years.
I don’t think risking my equipment on a cheap Zebby PSU is my idea of Value For Money + ***the HD 4670 and 5670 mirror each others performance except that 5670 has got DirectX 11 support ***for display as it can’t play any game with decently cranked settings, so I say follows DA’s advice get a decent PSU < FSP Saga II 350W > + HD 4670.
He already has one.
Apologies. I guess the OP already has FSP Blue storm Pro 350w :ashamed:
As ppl have suggested the HIS Raedon HD5670 is the best card in OP’s budget. But since he has only a CRT IMO the HD4670 would do just fine.
hiii,… sapphire gives more cooling than HIS Raedon HD5670… Sapphire was not available in stores… i got one online… so gonna buy… thank u..all . special thanks for u buddies DarkAngel, joel, alpha,
Check the warranty period offered by HIS and Sapphire respectively. Asus and MSI offer 3 years warrnaty. Go with HD 5670.
HIS offers 3 years warranty too. The ICEQ version of HIS has one of the best after market coolers.
He ordered two Sapphire 5670 via lynx.One for him, and other for my friend. :slight_smile:
wrong mate
Hd 4670 has 320 SP whereas 5670 has 400SP.
Also HD 4670 has 2Ghz effective GDDR3 while 5670 has 4.4Ghz effective GDDR5.
check out the performance comparison
MSI RADEON HD 5670 vs MSI RADEON HD 4670 BY ULTIMATE HARDWARE
5670 is 30~35% faster and DX 11 totally justifies the 1k price difference.
hey domi…?? ha hahah a grt…
