You probably need to check the security aspect of the application as giving 777 might not be really wise. Functionality as per the demo link is good, UI needs some work, though its quite simple but its not inviting. I hope this helps. Will definitely pull the docker on my self hosted rpi.
UI - yeah never been my strong suit. My goal was to just build something acceptable. No plan for color combinations currently. I have some more pressing features planned for v2 - encryption 2fa
777 - yeah, I think that is in the dockerfile. The thing is the alternate would require some advanced user settings, which gets complex and dependent on the server. I think
Nice project , would be interesting to see speed and performace , and where is this hosted. I used openmediavault and pi based hdd setup for similar results but this looks cleaner
Congrats for beginning such a project. This will help many of use having tons of data to be stored offline and who are looking for a vfm yet secured cloud option.
When you say $3 can you elaborate in details how much bandwidth and online space you get in this amount and the transfer rates etc.
And if one wishes to go for it can he simply follow the guide and do it or is there any dependency and so on.
If you can step-wise list it all I can help you test with chunks of data.
So this tool is geared more towards developers or techies who know how to setup their own server.. or who can setup a pi, then make it available online with a static ip OR something like cloudflare tunnel , if your home internet is behind a double nat
But if you just want to experiment - I use buyvm.net + blockstorage → install linux → ssh into box → install personal drive.
