Issue with zfs on omv
Hello guys so previously i had a truenas installation on proxmox with an 1tb 2.5 hdd for storage passed through to the truenas vm.
So i had forgot about it for a while and forgot all the creds(my bad should’ve written it down)
Then i had proceeded to delete the truenas vm and installed omv as an vm and passed the zfs hdd to it and even installed omv-extras and managed to import the pool
However i’m not able to use the filesystem of the pool in creating an file system
Any help will be appreciated!
Bumping the thread …
Was the zfs pool encrypted?
no it was not encrypted @napsterlabs
if you SSH into the system, can you see the data in terminal? If not then its not mounted.
im able to see the data in the terminal when i ssh
Copying from first hit on Google search:
hit the “discover” button on the ZFS screen
https://www.reddit.com/r/OpenMediaVault/comments/1guquap/cant_create_shared_folder_on_imported_zfs_pool/
My god i even installed omv and omv-extras and i imported using cmd why are some stuff so complicated!
