MiniLED 2.5k 240hz 16 inch Portable Monitor
Disclaimer this is an OEM Portable Monitor that’s utilizing BOE’s NE160QDM-NM4
Resolution: 2560(RGB)×1600, WQXGA 188PPI
Refresh Rate: 240hz
Panel Type: MiniLED
Max Brightness: 1100nits
Surface Feel/Coating: Matte
Aspect Ratio: 16:10
Ports: 1x Display Port, 1x Type C port for PD(Power Delivery)
Control Buttons: on/off button, +brightness button, -brightness button
Active Area(mm): 344.678(H) × 215.424(V)
Viewing Angle: 89/89/89/89 (Typ.)(CR≥10)
White Coordinate: Wx:0.313; Wy:0.329
Color Temperature: 6485K
sRGB: 100% coverage
DCI-P3: 100% coverage
Adobe RGB: 88% coverage
Display Colors: 1.06B (8-bit + FRC)
Condition: 10/10, used just for 30 minutes at friends house for testing the panel out
RFS: I dont have a working system right now to use this Monitor so its benched since last month ever since i imported it
That’s just protective plastic film on the surface
Yo champion connect your phone using cable and turn on the display and share some pics , it might help me and others to make a purchase decision.
I cannot type c is for PD only, I might go at my friend’s house again and update the thread with working pictures in 2 or 3 days
Type c only for pd ….. ok I guess I will pass .. good luck
Do you have a link you can post here where I can buy this (or a similar spec one) but a new unit if you don’t mind?
check pmmmmmmmm
How many dimming zones?
1024
10 charsssss
The panel details link you gave me mentions (for the 165hz version) the conncetivity is “Interface TypeeDP (4 Lanes) , eDP1.4 , HBR3 (8.1G/lane) , 40 pins Connector”
Can you ELI5 for me, what can and cannot connect to this? Does it support HDMI?
Like I have a AMD ThinkPad with a full HDMI port and USB-C too and also a AMD ASUS ZenBook with USB-C ports and a separate dongle I got with full HDMI …
will they be able to display on this portable unit?
I presume a regular (Ryzen) PC should be fine? What are the cables available? Thanks!
also - this sale says shipping risk is on buyer? so should i just get the 165hz unit new from your website with full delivery/DOA/warranty support? thanks
Interested Pm’ed
You posted this 5 months ago about purchasing from pindoudou, so what happened in the meantime for it to only arrive in December?
https://www.reddit.com/r/IndianGaming/comments/1n0fhmo/wts_25k_resolution_240hz_16inch_borderless_ips/
that monitor was sold to @marsweeed in november iirc and that monitor was IPS 2.5k 240hz not MiniLED 2.5k 240hz
That are just pure panel specs not meant for end consumer, Infact all monitor panels have eDP 40pins which they use to connect it with a display/controller board using a eDP 40pin cable
This monitor has a Display Port and a Type-C (only for power delivery) You can use with any device that has HDMI port but you would have to use a Display Port to HDMI adapter
The cables included are 1x Display Port cable and 1x Type-C cable
Yeah i posted that IPS monitor on reddit for sale and in TechEnclave as well, and it ended up selling on TE
Here’s the link to the sale
This is what eDP 40pins connector on a display panel looks like
And this is how a eDP 40pin cable looks like this cable is used to connect the Panel to a controller board
thanks for the detailed replies @ seller - should be useful for any other intereted buyers too.
GLWS
im in two minds thinking about getting this because already have a portable monitor for standby/backup use, so not very likely but thanks again.
your username OP : )
Woah, this is still available?
I thought it got sold.
its still available sry sry for the late reply
