MS teams: calls issues on RDP- No voice transfer
I observed this issue just 2 days ago.
For office usage, I have to connect to a clients vm (rdp) hosted on AWS via Amazon WorkSpaces. Each of us have our own client login (naturally) hence outlook/teams etc. are separate from my parent co. outlook/teams.
Never felt the need but that day I had to call to one of the client employees on Teams from that aws vm. I was able to hear him but he wasn’t able to hear me at all.
I was hooked to a BT earphones on my desktop (parent host). I switched to wired 3.5mm headphones using a “Y” splitter then too same issue, he wasn’t able to hear me.
But this isn’t the issue when I join calls from my desktops Teams app. (no matter which earphones I try) all is smooth sailing.
It was kind of naturally embarrassing for me as I called 5 times and it was the same issue.
I gave a try from my laptop and was amazed that same wired earphones worked just perfect right on the first call via same aws vm-rdp. (both the parties are able to communicate with each other) just like it happening the usual way.
For laptop no need to used the splitter as there’s some TXRX thing on the laptops jack but not on desktop.
So dont know what exactly is wrong from pc. As, using the same splitter or even any BT earphones, calls directly from my pc are working fine.
I’m connecting through my cabinets front audio jack via this Y splitter (mic/ear). Back panel cannot be sued here as cable length is limited.
Apart from this there’s no other audio issue at all.
I tried to temporarily login my clients a/c from my desktop but the account is binded by some policies so it can only work through authorized systems. (my earlier project client didnt had such restrictions)
Need resolution so that I dont have to depend on laptop for such scenarios.
Did you tried audio pass through while connecting to vm and checked?
Without passthrough other person won’t be able to hear your voice oven vm.
How to do that?
Then why on laptop I do not have to do suuh setting?
In team on the desktop in the VM, check the device configuration, you even have the option to do a test call, try that
Or try this before you connect to VM (on RDP prompt window)
We do not connect the usual way to aws rdp but its via amazon workspace login.. Thats how its designed.
Once entered the credentials it directly connects aka logins to the aws vm.
Teams audio devices shows some virtual audio. In drop down no other option.
In Teams test call when the bot lady asks to speak then after the beep I cannot my voice yet it says all tests passed.
One more generic query…
I uninstalled teams and removed all its directories etc. and when I freshly installed it, it still shows my last configured accounts.
Where is this info. stored? I wish to permanently delete 2 a/cs from the list.
For some reason MS Teams does not work well over RDP or virtual desktop and ms never responded with a proper solution
Seems so I read it on those shitty MS forums..no resolution yet while people are suffering since years now.
