Hi.. I’m Looking to buy PC for my sister. She is a Multimedia and animation student. She is already using a laptop. But it is not handling animations and video rendering. So, looking to buy a PC for her. I’m not sure about the budget. The software she uses at present are autodesk Maya, Adobe after affects, blender and photoshop. Please suggest a PC for her requirements. Thanks
What is your budget?
50K-60k
[*]What is your existing hardware configuration (component name - component brand and model)
NA
[*]Which hardware will you be keeping (component name - component brand and model)
NA
[*]Which hardware component are you looking to buy (component name). If you have already decided on a configuration then please mention the (component brand and model) as well, this will help us in fine tuning your requirement.
No preference
[*]Is this going to be your final configuration or you would be adding/upgrading a component in near future. If yes then please mention when and which component
Yes, This will be final configuration
[*]Where will you buy this hardware? (Online/City/TE Dealer)
Chennai
Open to online purchase
[*]What is your intended use for this PC/hardware
Animation and Video editing
[*]Do you have any brand preference or dislike? Please name them and the reason for your preference/dislike.
No preference
[*]If you will be playing games then which type of games will you be playing?
NA
[*]What is your preferred monitor resolution for gaming and normal usage
Desktop - 1440x900
[*]Are you looking to overclock?
No
[*]Which operating system do you intend to use with this configuration?
Just for your reference, I have had Intel i5 - 2nd Generation PC with 16GB DDR3 RAM but it won’t able to run/load Photoshop & BlueStack. At that time I add basic entry-level GPU and all starts working OK.
I would suggest looking at the Recommended (not Minimum) System Requirements for each of those Softwares first. They should be documented on their sites.
Out of all select the one with the highest requirements; that will be your starting point.
Also Pugetsystems do a great job of suggesting hardware for content creation based on specific workloads -
[www.pugetsystems.com/solutions/content-creation-workstations](’
Western Digital Blue SN580 1TB NVMe Internal SSD (WDS100T3B0E)
6080
CPU Cooler
DeepCool AG400 LED Single Tower 120mm CPU Cooler (R-AG400-BKLNMC-G-1)
1799
63649
Also please suggest a good basic graphics card to add to this config(preferably not used cards). Will add graphics card if there is any rendering delays.
The AM5 one. LGA 1700 is a dead platform. The 7600 isn’t too far off in multicore performance, has a better integrated GPU, is more efficient, and gives you an upgrade path.
The i5 14500 is noticeably more powerful, heck R7 7700 doesn’t get a win over it in all productivity benchmarks. Someone not tech savvy will likely not care about platform longevity & prefer the extra performance instead. Hence I recommended i5 14500 over R5 7600. If it was R7 7700 vs i5 14500, I will recommend R7 7700.
Buy RTX 3060 12GB later on for 25k or lower if GPU is really required, else get a used card for cheap.
Agree with @@OMEGA44-XT. 14500 has completely toppled the mid range CPU segment. For productivity workloads, it’s the best in it’s class. That being said, if you plan on using the setup for rendering purposes without a dedicated GPU, you’re better off choosing the AMD build. The Radeon graphics perform so much better that Intel’s UHD 770. In any case, if you’re gonna go with the Intel build, don’t get 1x 16GB RAM, instead get 2x 8GB RAM for dual channel benefits. Also, if possible, try and get a used GPU (at the very least, an rx580 ~ 6.5k) because it’s pure pain to render stuff without a GPU.
I will recommend 1x16GB RAM now & buying 2nd 16GB RAM stick later. This leaves room for upgrade to 64GB RAM if needed, considering the rig is for productivity, not gaming at all. Dual channel doesn’t help productivity stuff noticeably to consider 2x8GB.
Hi bud! I think you should consider spending more towards a GPU since it will help a lot with rendering. Blender needs a good GPU to render well, especially if she will be working on complex projects like 3D models. Neither the i5-14500 nor the Ryzen 5 7600’s integrated graphics will be enough for that. They’re better suited for basic tasks like browsing, Excel, or Word.
I would suggest going for a 3060/3060 Ti/3070 to handle rendering. You could also consider the [12400F build](’
If I had to choose between the two builds you mentioned, I’d go with the 7600 build for better overall performance. Here, 7600 has better igpu. I personally don’t trust Intel after their recent issues and layoffs. For stability, longevity, performance, AM5 is the better choice. Lemme know what you went with n why. Till then o7.
