A friend of mine, has a PS4 Pro from 2017 until now, who doesn’t have a gaming PC. He plans to import a PS5 Pro disc version from Dubai for 70K. I suggested to go with a PC, which would be more useful to him,
but he doesn’t agree with that. He says a PC won’t provide 120 FPS gaming within that budget.
He doesn’t have a 4K 120 FPS-capable TV. He plays on a Samsung monitor in his room because his mom won’t allow him to use the hall for gaming. With the monitor he has, he has a budget of 80K.
I told him that most PlayStation games are available for PC. If any new ones are released, they typically come to PC within a year or a year after their initial release, but he doesn’t agree with that.
Please share some build suggestions to convince him. He is okay with a used GPU but doesn’t want any other components to be used.
He mainly wants the PS5 for the backward compatibility of PS4 games. Is the PS5 killer real?
your friend is in the same situation as me. Got a ps4 pro from dubai in 2018 still running it to this day, waiting for the ps5 pro. Now that its out quite lukewarm perf increases and no disc drive so all my physical games will be rendered useless unless i pay 18k for a disc drive. I was thinking for a 9070 xt build but the prices are scalped from the retailers nowadays and i do not want to pay them to condone these practices, i am stuck playing a lot of JRPGs which you’ll be surprised how many still are released for the ps4.
He plays JRPGs too they look like some kind of mobile games he plays on the PS4, He got frustrated with gow Ragnarok at one point, so he explored all the PS4 games
Unless he wants to play games that are exclusively on the PC like league or cs2, let your friend get the ps5 or ps5 pro
GTA 6, the biggest upcoming hyped game is exclusively coming out for consoles and will most likely stay exclusive for 3 years before it comes to PC. I honestly dont think there are really good ps5 pro killer builds for that price without cutting corners somewhere like getting used parts as someone said.
GTA 6 is the reason he is getting the PS5. There are reports in the market about a shortage of sealed PS5 units in Dubai. His uncle visited two sellers in different areas, but they both work under the same head dealer. They contacted his uncle and said that the PS5s are selling quickly due to GTA 6, so he should buy one fast.
I don’t think availability is bad lol, if I want to I could contact a few stores in bangalore and sort out a grey market ps5 pro within days. Sounds like they’re just trying to scare uncle, would have worked back in the days where information wasn’t so readily available, hell I think you can even order a ps5 via the same fast delivery apps we have here like blinkit.
Yes, they are hyping up his unc to buy PS5 Pro. The PS5 Pro costs more in India because the 6 GHz, they were higher their margins. Yes We can get the PS5 on Blinkit, as it is available there. His uncle is coming in August, so he needs to decide soon
A dedicated gaming console has advantage of games be optimized to a particular singular hardware, the hardware itself may or may not be faster than the same price PC. On same priced PC the game will give you graphical settings and say set it according to your hardware by yourself or we can auto detect and apply it, they can only give you few presets, now your PC hardware may or may not be a exact match for these presets, so now you have go deep into advance settings and check each settings, and set accordingly such that you always get 60 or 120 fps and also while doing that you get max graphical fidelity that your pc can handle, because often times the auto-detect is very conservative and it turns off most of the things.
Ultimately in the end you yourself become the final optimization layer for the game. It gets messy.
Usually console is prefred choice if player doesn’t have lot of time. They just want to game and not be affected by these grahical shenanigans.
I totally agree with what you said. I’m just curious if it’s possible to build a similar PC within that budget. His own brother also suggested getting a PC, as he has an old sandwich maker laptop, PC might be more useful for him.
The 7900xt is available for the same price as the 9070 non-xt and performs the same. Overclocked 9070s perform the same as a 7900xt. Check this review out if you don’t believe me.
With 9060XT 16GB, PS5 pro killer PC will be cheaper than the current possible PC builds. I won’t recommend 7900XT, unless under 50k. Lack of FSR4 is an issue.
This i5 12400 based rig for 45k will be good for GPUs till 7800XT, I was myself using i5 12400 + 7900GRE till a month back.
Say 9060XT 16GB is under 40k, overall will be a good build for 85k. 9060XT 16GB will likely perform like 7700XT but AMD is claiming 5060Ti like performance. In either case, will be good. 5060Ti is also near 45-46k. PS5 Pro GPU is said to similar in performance to 7700XT.
For used GPU, 3080 10GB around 25-30k will be a good deal but doubt you will find it. It is definitely not worth paying 35k considering the VRAM & that it is used w/o warranty mostly now.
Even when Linus made the PS5 Pro killer video 6 months ago, he used these exact components. It was almost equivalent to the PS5 Pro. So, how will it compare to the RTX 5090 or AMD latest GPU? Wouldn’t a PC always be a legend killer?
That pic I attached has GPUs till 5080. 5090 is another 50% faster than 5080, so like 3x performance of a 5060 Ti. 9070XT is present in that pic, so look closely?
Top PC hardware will always be better than consoles but usually consoles are cheaper vs equivalent PC hardware, which is surprisingly not the case for PS5 Pro.
do a 3060 12gb (*not *3060 ti) build and it will easily come under budget specially if you buy the gpu second hand, most gamers would happily accept lower than low settings and shitty upscaling from 720p to 4k when playing on consoles, yet bitch and moan when they cant run max settings on their low tier GPU.
Not a *single *game runs better than the build above ***if ***run on PS5’s equivalent settings and using equivalent upscaling (check DF’s coverage for equivalent settings and benchmark) because even the PS5 pro is hobbled by the shitty CPU they have, plus you get the benefit of DLSS (specially after DLSS 4.0 where performance is equivalent to DLSS 3’s quality mode).
Also peeps are seriously buying a console just for GTA? like seriously?!! I mean I kinda get if you are into MP with a bunch of friends and lobbies at launch will be really fun without any hacks or griefers, but SP on GTA has sucked for a while now, last good SP campaign was GTA 4 and best one was San Andreas where you could spend hours just fighting gang wars. I dont really get the hype behind gta 6 but thats me
