PSU review: CORSAIR RM750e (2025)
Upgraded my PSU from Cooler Master GX650 to Corsair RM750e (2025) on December 26th 2025 3 weeks back mainly because I wanted a silent PC and I am underwhelmed by the Corsair. Its still noisy. Not sure if its due to my fans, but I don’t think so, all of them are Arctic -
  1. Arctic F8 80mm
  2. Arctic F12 Pro 120mm x2
  3. Arctic P14 120mm
  4. Case fan from Nxt
Also cpu fan is Noctua NH-U9S which is supposed to be silent.
Also PSU tier list says this is B+. Should have checked this before buying :frowning:
Bought it for Rs. 9.2k.
My complete build - https://pcpartpicker.com/list/KCgKFZ
I made the same mistake but luckily was able to exchange it to RMx as i found out on the same day. It was only 800rs higher than the RMe. Also the RMe comes with 7 year warranty while the RMx comes with 10 year warranty.
But it’s not a bad PSU so you’re fine. People are running their PCS with tier C and below and never face any issues.
