Thoughts on this monitor stand?
Stand
cant do a monitor arm because my desk doesnt have any space at the back. and i dont want one of those V shaped stands either.
Don’t recommend it. The base looks too thick & at that point just use the stand that came with your monitor.
Also i recommend a proper monitor arm at that price. You can always mount it on your left or right side of the table. Amazon basic pro gas spring is great if your monitor size is 27 inch or below. Don’t recommend it for 32 inch.
i literally cant do any monitor arm at all. and the stand that comes with my monitor is a problem in itself
Most flat stands will be like the one you shared. If you don’t mind zero space on your desk then its a great option.
If you want free desk with there being no option to install monitor arm at back & sides then there are just two options.
  1. Grommet Mount - You will need to drill a small hole somewhere on the desk.
  2. Wall Mounting
