32 bit OS on C: and 64 bit on D:
adi_vastava said:
^^ Not at all My brother :),
looks like you are new with computers, no worries at all.
I have actually used 3 OS in three partitions, just make sure you install XP first and than Win7. And you'll be good to go. Later on if you feel that you do not want to use XP or the XP compatibility mode is good for you, you can remove XP too.
good luck.
Yaa i m bit new to such things :ashamed:
Anyways thanks a lot.....i will get back to you ..if i suffer any probs ..ok:)
vibhorwadhawan said:
If your RAM < 4gb, Would suggest you to install both XP and WIN 7 32 bit.
yaa,,,,its 4 GB 1333 MHz DDR3 RAM.....so...
