SiriusB said:^Got it from the one and only delta peripherals in ritchie street. He's the only distributor for chieftec in tamilnadu.
SiriusB said:^I would be that dude.
Chaos said:BTW you'll not get 80GB and 160GB 7200.10 drives cos afaik they don't exist.
SiriusB said:320GB 7200.10 was what I asked of him, but he wasn't sure he could get one before this month was over and he only had 320GB pata. So I settled for 300GB and that too he had only one of.
So, hey, you must know some good shops I can try for the hdds in ritchie street. The only other decent shop I know of is Lotus.
Chaos said:SV35 uses the same perpendicular recording as 7200.10. Infact if you intend to use it as a dump drive, its better than the 7200.10 cos it has higher transfer rates. However latencies are slightly worse than 7200.10 (13ms vs 14.5ms). BTW you'll not get 80GB and 160GB 7200.10 drives cos afaik they don't exist. My advice... get either the 7200.10/SV35 320GB instead of 300GB.
