ok guys can you beat this ??
127.0.0.1 sidepage.co
127.0.0.1 streamride.co
127.0.0.1 ui.sidepage.co
127.0.0.1 ui.streamride.co
Add these lines to host files on windows and restart windows you will see the popups no showing up anymore.
Do you know, on torrents alliance users get around 40 mbps? And there's no stupid fup.
private torrents have a private flag.. thats inbuilt while creating the torrent and hence any local IP is exempted from being discovered... but there are ways you can do that but those are tedious methods.. anyway private torrents 99% times wont support LAN peers. And if you want a quick boost of your ratio then just down stuffs on peering and cross seedDo alliance support peering facility for private torrents? Anyone uses private tracker and downloading from private torrent site? What is speed the do u get?
I use both,but mostly IPconnector...webpage on my side seems to be working fine!!Guys!
Do you all using IPConnector or Web page for log in and log out ?
Currently facing problem with web page.
No problem while log in.
Once logged in then the page not opening and unable to log out.
Call CC but they have no clue just tell me to use IPConnector .
But,I don't want use IPConnector .
This one not working for me.I use both,but mostly IPconnector...webpage on my side seems to be working fine!!
http://10.254.254.1/0/up/ this is the webpage currently,used to be different few weeks ago...
