Revolution
Contributor
wat is ur BB connection and plan ??Alliance have a plan called Zoom Plus @499+Tax.
Normal speed 440kbps and peering 5mbps.
Guys do u know if alliance is there in behalaPrime is definitely better...difference between the price would be roughly around 50-60 bucks
@Revolution why would you stay with zoom plus when you are getting much better perks with Prime??
Dude what is Ur plan's speed rating and how much do u get when downloading files through IDM, torrent (not peers)[DOUBLEPOST=1369663454][/DOUBLEPOST]Like torrents download from piratebayAbsolutely no idea about contention ratio
Dat means u have ratio 1:10I am on Preferred plan 700kbps gives around 80 kBps download speeds through IDM/torrents
night plan starts from 1am to 9am-4mbps giving close to 400 kBps or higher!!
Most of the torrents are peered even if you download from piratebay...
Thnx a lot bro!!!100 kbps each of course,the full 1 mbps bandwidth is always available for the users!
If only one person gets then 1 mbps for him to enjoy...
But you know,don't worry about contention ratio too much. I've been using internet for ages and never have I got a speed lower than my plan's internet speed...![]()
Actually my parent pay for this.
I don't earn anything so I can't complain.
Well do u get good speed in all rooms where u find signal, or does the speed reduces as u move away, though there was some signal being receivedoh,but still, you could try your luck you know...maybe when they are in a good mood![DOUBLEPOST=1369709182][/DOUBLEPOST]I use this one,works great for me...range is pretty good too for my home!
and it is very cheap
http://www.flipkart.com/tp-link-tl-wr740n-150mbps-wireless-n-router/p/itmd7hn92fytnj3h
