shravank30
Discoverer
Emperor said:Cheap quality material used, just after 1 month of use water flow decrease to drops, service person visit 2-3 times, fix it but continuous water flow can't long last than 15 minutes & again water flow tuns in to drops. Not recommend for house who have more than 2 members & need more than 8 lits. water in 8 hrs.
I am using the BARC water filter of Aum Technologies called Neermay
As I am in Bangalore & they are based in Mumbai, My building plumber installed the same in 30 mins. Its that simple
All required items down to the T are sent with the item.
I get about 5 litres per hour output.
Neermay Filter has 2 filters, a pre filter & the main filter. So I think thats why it does not get choked.
They recommend just washing the filter every 15 days to 30 days under running water with gentle hands. No other maintenance required for 3 years.
This same filter is used in NPC for making mineral water for use in their power plants.
As there are no chemicals involved the running cost & wastage of water is zero
I just store the purified water in a sealed tight Tupperware container
Hope it helps
