laxmi24
Contributor
I am looking for a cabinet with minimum of 3 X 5.5" external bay and 2 X 3.5" external bay, within Rs. 2K. And i also need 400w or 450/500W SMPS. If the SMPS comes with the cabinet i agree with Rs. 2.5K. Any local SMPS will OK.
On the internet i found one product within Rs. 1.7K with the bellow specification. It is in my budget too. But it Has two problem.
Product view : iBall Entry - Level i8190 Cabinet
Specifications:
Brand : iBall
Type : Cabinet
Technical Specifications :
International designer series. Sturdy cabinet with better space management.
5.25 Inch Bays: 4 External bays
3.5 Inch Bays: 1 External bay, 5 Internal bays
Motherboard Form Factors: Standard ATX & Micro-ATX motherboards
Front USB Ports: 2 Front USB Ports
Front Audio Ports: 1 Audio-out Jack + 1 Mic-in jack
Bundled Cooling Fans: Bundled with 1 x 8cm cooling fan
Extra Cooling Fan Provision: 1 x 8/9/12cm (Front), 1 x 8cm (Side)
Heat Vent: Heat vent on side panel for Processor and Add-on cards
Power Supply: 250Watts Power Supply.
Available Colours: Black + Silver
Dimensions: 15.8 x 6.8 x 16.6 inches (H x W x D)
Now the tow problem is
1> It has only one 3.5" external bay.
2> It comes with SMPS which is 250W.
Any other model friends?
Friend any cabinet with no SMPS is appreciate. I will purchase the SMPS in separate. What should the cost of a blank and very simple but full tower cabinet. or with 400w or more SMPS.
As do not use my PC for gaming purpose so i do not need too much cooling system. the processor fan and two other fan in cabinet is fine for me.
my motherboard is micro ATX.
Please give me some suggestion.
Specifications:
Brand : iBall
Type : Cabinet
