kartikoli
Innovator
yes i am considering the sameHades. said:@karti
i wud suggest u to go wid the rig DA suggested... Why buy something which is old... and i think all the p4 rig parts wud b out ov warranty... So a caution sign from my side ... Plus Sempron 145 is a 45w CPU... So u can also use the rig DA suggested as a 24/7 downloading rig... it will consume way less power than the p4 rig...
will surely chk out this later [just came bak]nehaladsul said:Get the Acer eMachines eM350 Netbook that has just been introduced for 11k with the MTS USB Internet stick.
Best buy for you IMHO.
got ittrigger said:@OP <ygpm>
Rockfella said:1GB Ram would be good with 160gb hdd however a dual core processor would be better in the long run imo.
locally diff. between 1GB and 2GB is almost nil... no point saving 100-150 odd.... i can still save that with cheap quality ram as a dealer is quite friendly and i have been buying product from him for past 3-4 yr.
on HD even 40Gb would do
@ dual core ... i think that will shoot my budget
