Cogage Arrow CPU Cooler Review – Dual Rad FTW!
Some time ago we reviewed the Cogage True Spirit which was the first cooler from Cogage which is a new brand introduced by Thermalright. We were really impressed when we tested the True Spirit because of its light weight, compact size and yet decent enough performance considering its lower price.
Now Cogage has come out with a brand new cooler which is supposed to be superior to the True Spirit and is also attempting to take on the mighty TRUE that has held the performance crown for quite some time now. This new cooler is called as Cogage Arrow and is a dual radiator design. Looks wise its like the IFX-14 just a wee bit bigger :P
It remains to be seen whether this massive cooler is really capable of achieving the high goals it wishes to accomplish.
Specifications and Features -
  • 4 X 8mm large sintered heat-pipes efficiently remove excessive heat away from the CPU, allowing for great Overclocking potential
  • Nickel Plated Base and Heatpipes, increase the longevity of the heatsink by slowing oxidation and deterioration rates… maintained performance over time
  • Double fin stack design, provides each tower with an impressive 147 x 103mm of surface area for heat dissipation
  • Special Arrow fin design, which allows cool air to pass through while rapidly moving heat away and maintaining a quiet operating volume
  • Soldered Heat-pipes, Fins and Copper Base, ensure all components maintain the higest of Thermal Efficiency
  • Support for Multiple-Platforms: Intel Socket 1366/1156/775 (AMD Socket AM2/AM2+/AM3 optional)
  • Includes a Quiet 120 x 25mm PWN controlled fan
  • Capable of supporting up to three fans for the Ultimate Enthusiast (38mm will fit between the two towers)
Cooler Dimensions: Length 147mm x Width 123mm x Height 160mm
Cooler weight: 825 g (excluding Retention Hardware and Fan)
Heat-pipe: 8mm Sintered Heat-pipe*4 units
Cooler Base Material: C1100 Pure Copper with Nickel Plating.
[BREAK=Box, Packaging, Contents, etc.]
The Arrow supports all the major Intel platforms, ensuring maximum compatibility. Unfortunately it doesn't seem to support the AMD platforms out of the box. It would have been great had they included AMD mounting kits for even more compatibility. You can purchase the AMD mounting kit separately.
As you can see from the basic specs mentioned on the box, it’s not exactly a lightweight cooler like its predecessor, the True Spirit. Not a biggie considering its size and expected performance.
Bear in mind when coupled with dual fans or a single high CFM fan the total weight will touch 1 kg. Be sure to check your motherboard mounting to prevent any mishaps!
The cooler is packaged meticulously with sufficient padding from all sides and a sturdy box to protect it from getting damaged during transportation.
The cooler is fastened to the box with 2 cable ties so that it doesn’t move around and remains firmly secured. The holes in the cardboard allow you to pull out the cooler while the eight small holes are for safeguarding the heatpipes
The packing in between the twin radiators is extremely crucial because if at all the box is subject to excessive pressure due to careless handling by the courier guys, there is a possibility of the heatpipes getting bent and the cooler getting damaged.
[BREAK=Product pictures]
The Arrow has nickel plated heatpipes unlike the True Spirit, a good and useful feature for people living in coastal areas.
The fins are slightly bent towards the edges, this allows air to circulate a bit longer which leads to better heat dissipation.
The finishing has improved but there is still scope for improvement.
Finishing of the base is much better than the True Spirit with hardly any machining marks
The heatpipe endings could have been finished in a better way, like the small caps used in the True Spirit. Only one end of the heatpipe is capped with the other end in the normal pinched form.
Please note that we say this from a purely aesthetic point of view, this does not affect the performance.
The fins of the radiators are comparatively thinner compared to the ones on the True Spirit and TRUE. So they're also more prone to bending, care has to be taken while handling the cooler.
The installation kit includes mountings for LGA 1156, 1366,775 along with a tube of Thermalright’s Chill Factor TIM, a spanner, few damping strips, bezel sticker and manuals.
Separate manuals for all three Intel sockets.
Since the mounting holes of Socket 775 and 1156 are very close to each other Cogage has made oval holes for the mounting clips allowing them to give a single set of mounting brackets for both sockets.
The bundled 120MM fan is the same that comes with the TRUE Spirit.
Along with the Arrow, Thermlaright was kind enough to send us something else which aided us in the testing process.
Its their new X-Silent 140 fan. This is a 140mm fan which can be used with this cooler since this cooler can accommodate 140mm fans.
Thermalright X-Silent 140​
Don’t be fooled by its low RPM rating, it will be silent yet capable of moving some serious air thanks to its large translucent blades.
Accessories include molex adapter, screws and rubber grommets
Sleeved cable, nice!
Since it’s a 25mm fan it fits between the dual radiators with plenty of room to spare.
Now that we are done taking a close look at the cooler, let’s proceed to the actual installation. For demonstration purpose, we have used EVGA Classified motherboard which is a LGA1366 platform.
[BREAK=Installation]
The Arrow shares its mounting mechanism with the Ultima 90i and the IFX-14 but with some significant improvement. Once both screws are fully tightened the mounting is very secure without any hint of movement. This type of mounting also allows you to swap the CPU without removing the whole motherboard.
Thanks to EVGA’s humongous NB cooler, the Arrow just fits on this board. But only one type of orientation is possible; fans blowing towards the top of the cabinet unlike the conventional way. But this is not a problem since most of the new gen PC cases have the PSU at the bottom and nice big exhaust fans on the top.
This shouldn't be a problem on other LGA1366 boards though.
Just look at the sheer size of this cooler! The Classified looks like a mATX board with this monster mounted on it. The Classified isn't a normal Full ATX board, its slightly bigger and this should give you fair idea as to how big this cooler really is.
This is what the monster looks like when it’s completely outfitted with the maximum number of fans it can accommodate.
We thought 2 x 120mm high CFM fans is an overkill in most systems except for Nehalem based ones but looks like Thermalright thought the other way round, ‘Two is passé, we should have 3!’
You can use 3 fans with this cooler! Who needs that anyway? OK, maybe the hardcore benching guys would but we don't see the average Joe going for such a setup.
[BREAK=Test Setup and Testing Methodology]
Test Setup -
Intel Xeon W3570 CPU
EVGA Classified Motherboard
3 x 1GB Crucial Value DDR3 1333MHz CL9 Memory
Corsair HX1000 PSU
Seagate 500GB SATA II Hard Drive
Galaxy Nvidia Geforce 9800GT GPU
Windows 7 64Bit Ultimate Edition OS
For full load testing we used LinX software which can stress the CPU more than any other application available at our disposal.
[BREAK=Results]
Since the TRUE has been our favorite for extreme AIR testing till now, we decided to include it in our testing so that we could gauge as to how the Arrow fares against the mighty TRUE.
As you can see in the above graph, thanks to the 2 radiators of the Arrow, it beats the TRUE under load but at idle the TRUE does a better job when both the coolers are used in passive setup.
Then we bumped up the CPU to 3.6 GHz and we see that the Arrow starts showing its potential here, comprehensively beating the TRUE in both idle and full load scenarios.
Now with the CPU running at 4GHz and both coolers being cooled by a single low CFM fan, both coolers are close to each other at idle but the Arrow edges out the TRUE under load
Keeping everything same, we just put a single high CFM fan instead of a low CFM one. Let’s see how much of a difference it makes. More or less the same scenario as we saw above, just that the temperatures have dropped at idle as well as for full load for both the coolers. Shall we say, we are already liking this cooler? Alright, not so fast, the REAL test is yet to come.
At 4.3GHz, we are really pushing the coolers. We are using 2 low CFM fans now for both the coolers. Again the TRUE beats the Arrow at idle whereas the Arrow continues its dominance at full load.
The final test, with 2 high CFM fans on both coolers, the TRUE still manages to edge out the Arrow at idle but sadly loses out at full load tests.
Since Thermalright sent us the X-Silent 140, we decided to run a few tests to see how well it fares. We ran tests at 4GHz and 4.3GHz and the results are in the above graph. Not bad for a silent fan is it?
[BREAK=Conclusion]
These tests just show that the Arrow manages to comprehensively beat the TRUE where it really matters! Should we say that we have found a worthy successor to our beloved TRUE? I guess we have.
Although the TRUE ruled the extreme AIR cooling segment for a very long time, it was quite obvious that there would be a cooler which manages to beat the TRUE.
The Arrow manages to do just that. Although we have still not tested the Noctua D14 cooler which was launched recently, we would like to test that one to see whether it has the same potential as the Arrow and would also be keen to see who emerges the winner between the Arrow and D14.
Edit - Technic 3D has reviewed the same cooler and in their testing the Arrow beats the D14 by a decent margin.
Whether or not this cooler becomes a success depends on how well Thermlaright prices it. One of the reasons for the TRUE’s success lies in its price. It was excellent VFM for the kind of performance it delivered.
Lets hope Thermalright repeats that with the Arrow too. Expected pricing is ~3.5K which will make it a worthy replacement for the TRUE in terms of pricing as well
So all those benchmarking enthusiasts out there, you know what to buy for your AIR based benching endeavors!
Thanks to Thermalright for the review sample.
Score Card -
Features : 9/10
Performance : 10/10
Value For Money : 9/10
Overall : 9.5/10
Reactions: 4 people
Re: Cogage Arrow CPU Cooler Review – Dual Rad FTW!
apollyon said:
Prime ABGB is a renown computer hardware dealer/distri in mumbai
Computers, Peripherals, Cameras, Laptops, Gaming Equipment Tech Heaven
WOW! Thanks for that link! I've searched their site for Cogage Arrow, but didn't find it. However, I have a hunch that they might have it in their place. Its situated in Lamington Road, the Mecca for PC parts. Its close to my place so I can visit them anyday ;)
apollyon said:
And btw the 555BE is available locally, a user named harakiri bought one recently iirc.
I searched prime and found it there for Rs. 5300 :hap2:
apollyon said:
I have seen that page for TR bolt thru kits but you'll need a kit which will be similar to the one that the IFX 14 has and thats the 939 bolt thru kit. But i dunno if it will fit an AM3 board
Hmmm... I'll try emailing Cogage & thermalright and ask them which kit will work for AM3 board. I've searched prime and found that Thermalright 939 Bolt-Thru-Kit is available for Rs. 520
So Arrow will Cost me Rs. 3500 + Rs. 500 kit + Rs.1500 Fans = Rs. 5500
Costing more than the CPU itself! :S
Since Arrow is one huge cooler, won't it be better to use 140mm fans? I know that it supports one 140mm fan in the middle. Can it also take 140mm fans on the sides? If yes, then I'd then go for a 3x140mm fans setup* Since you have this cooler, can you please check if it can take a 140mm to its side? I was thinking of 140mm because 120mm doesn't cover the cooler completely, like 140 does!
Thanks. You have been very helpful for me :)
* Once an interview asked a man, why did you install a jet engine on your car? And the man answered, because I can!
The cooler comes with a single set of 140mm clips, but afaik you can buy two more sets of clips and attach two more fans. But the cooler + 3 140mm fans will easily touch 1.1-1.2kgs which imho will be risky for the board.
What I would suggest for the 555BE is the cogage true spirit. Prime has it on their site for 2.1k. Its a very VFM product and not restrict your OC at all
LGA 1366 HSF's reviewed: Noctua Vs Cogage - Reviews and Previews | TechEnclave
It handles a 955BE @ 3.95ghz (1.5v) with ridiculous ease.
You will need to buy the AM3 bolt thru mounting kit separately.
The cooler comes with a decent 120mm fan so the whole thing will cost you ~ 2.7k
Can't the provided clips somehow be made to work with 140mm? A little bending perhaps?
Sweet!
I know that we can change the fan, but can we install 2 fans on it?! In the review you mentioned, "CPU at 3.95GHz/1.5V with 2 x Nidec TriBlade Fans in Push-Pull config. (Each fan is rated at 130CFM)" Was this in germane to TRUE Spirit?
And I see that the review was done in winter. So the ambient temps would have been low. And since I'd need to buy high-CFM fans and mounting anyway, the only money I 'save' would be from the price different of the cooler itself, i.e. 3500-2100 = Rs.1400/- And if I consider than Arrow gives 2 fans with it, then the price difference gets even narrower; of less than a 1000.
Since the ambients are very high where I live, I'm being a bit too circumspect before shelling any money. I'd be pissed if I can't OC my PC to 3.8GHz 24x7 because if didn't spend another <1K.
Though I'd keep an eye on TRUE Spirit and dig a bit more on it. If it can perform well even on high-ambients and can take 2 fans, then I'll be happy to save a bit of moola from investing in it!
^^Arrow does not come with two fans, it comes with a single 120mm fan (same one that comes with the TRUE Spirit). The 140mm fan in the review was a separate item
You can install two fans on the True Spirit and the test settings mentioned were common for all the HSF's in that review
Ah! mea culpa. I knew that the 140mm was separate, but I thought that the 2x120mm were included. Mea culpa!
Though after an insane amount of contemplation, I have decided to make my own water cooler with copper pipes running outside the case in an icebox filled with ice-water.
Only if can can get a way to make the waterblock (I'm looking for sketches and how-to's) then I'd make this! I can use my fridge to cool water and make ice in the night and use it in the day!
It'll give me something to do! Since the summers can get very hot, even the best air-coolers will be crippled due to high ambients. But if I can use lower-than-room-temperatures, then I can free myself from that bondage.
I'm now reading the posts of people who have done this before. Hopefully, I'll learn something from them and will be able to make myself one.
Thanks for all your help :hap2:
