PC Peripherals CPU Fan NOT WOrking
GuruGulabKhatri
Galvanizer
Yesterday night suddenly my pc went off.astonished,i turned it again and again my pc went off after a few minuites.I Shut it down and then today morning again i turned it on and again it went off abruptly after an hour.after turning it on forthe third time i noticed that the cpu temp is 113 degs. i looked inside the cabinet and the saw the cpu fan is not running now my questions are -
1.Pc is Still tuening on fine so my cpu is okay right? Its a Propus
2.Is The CPU Fan covered under CPU Warranty?
3.If Not Can you Please suggest a CPU Fan/Cooler for cheap? i know Coolermaster Hyper Is The Best but I Cant Afford it right Now
TIA
EDIT
What type of warranty does AMD provide for its processors?
Processor-in-a-box (PIB): AMD provides a three (3) year limited warranty on its line of processors sold through the AMD Processor in a Box Program. Your vendor will generally provide warranty service for the first 30 to 90 days, after which warranty service will be provided by AMD for the remainder of the 3-year warranty. To obtain a prompt exchange, AMD recommends contacting the vendor or system builder as a first attempt for warranty services. If your vendor is unable to provide warranty service, you are unhappy with the vendor’s support or you are outside of your vendor's warranty period, you may submit a warranty request directly to AMD.
The 3 year limited warranty applies to the processor and heatsink / fan (HSF) provided in the PIB package.
